Twin Seq. Dry sumping for beginners :D
aauser
I would try it in the pink before the brown everytime
gareth
Turbo-Brown
- Boost Junkie
The noise must be able to get through the turbine to an extent giving the idle noise (this is why I reckon having two turbines in series will eliminate the need for silencersAnother question :
Does the exhaust note come trough the wastege or the turbine wheel at load
Certainly you hear the exhaust noise ramp up as the wastegates open on boost.
Think I'll go with a full 3" from the turbo back with a straight through silencer and run the WG outlet in 2" pipe through the same silencer at the rear of the car.
Should make it near enough silent at idle and then loud on boost
e30_Turbo
- Boost Junkie
Alex,
Running a screamer isn't at all a issue, either legal wise or noise wise. Have it pocking out under the drivers side arch, save running the pipe all the way to the back.
The screamer does pop, fart and throw flames out but that only happens at full boost so you have the exhaust booming already, although you can still hear the screamer and damn is it cool
P.s. just windscreen and emmisions need before I'm legal again! BRING IT ON!!
Turbo-Brown
- Boost Junkie
Awesome, you re-made your mani then Mark?
Turbo-Brown
- Boost Junkie
Hooray, £139 for 1m of 1 1/2" pipe, 1m of 2 1/2" pipe and 10No. tight radius 1 1/2" 90degree bends all in S/S grade 304.
Going to steal the T25 flange (which neatly fits the HX27) from the Mi16 and replace that when we need it.
FINALLY the wheels are in motion
Ant
- Retired Team Member
Alex, your HX27 have internal W/gate ?
I have one too, 11cm housing for external, just wondering.....
Email FTW
Turbo-Brown
- Boost Junkie
It does indeed, it's got a bloody hard spring in it too!
Not that I need the internal gate though as the divertor valve does the boost regulation duties for the HX27 so I was just gonna bolt it shut
Ant
wanna trade ?
Email FTW
Turbo-Brown
- Boost Junkie
Ooh is it brown-new? Could be tempted, how do I find out what housing mine's got dude? Holset seem to have a bewildering array of possibilities!
I take it that if I undo the V-Band that holds the turbine housing on it'll just pull off over the wheel will it? I've not really taken either turbo apart yet, except the cold side of the H1C, to be amazed at the size of the compressor wheel
gareth
slight trivia, holset use loadcells that i designed to measure the clamping load on their 'V' band clamps in the QC department ;)
Ant
Alex, she is brand new dude.
you should have an assy number on yours, and the numbers on the casting for the hotside reveal the housing size.
Email FTW
Turbo-Brown
- Boost Junkie
No idea what the numbers mean, might mean something to you though dude?
Assy No. V001000
And cast into the exhaust housing is 89-10410
All very cryptic
Assy No. V001000
All very cryptic
Hmmmm, can we deduce from that that the V-bands should be done up to a specific torqueslight trivia, holset use loadcells that i designed to measure the clamping load on their 'V' band clamps in the QC department ;)
Turbo-Brown
- Boost Junkie
Ok, here's a question for everyone:
I'm hoping to start the manifold this weekend as I need a break from working on other people's stuff, so should I put my EGT probe in the mani or in the down-pipe?
Cheers!
Cheers!
e30_Turbo
- Boost Junkie
I've read some use only one runner in the manifold but I'd think downpipe would give a better allround reading, what did the instructions say?Turbo-Brown wrote:Ok, here's a question for everyone:
Cheers!
Gunni
As I said on the tech you want the highest reading,
wich is on the least cooled part of the engine, the #6 cyl.
Turbo-Brown
- Boost Junkie
Well, I've FINALLY made a start on the fabrication!
Will post some piccies at the weekend when I can borrow a camera but I've spent the whole day just working for myself on the car and have made the log part of the manifold.
I set my mind to doing as good a job as I could and making the joints as tight as possible unlike the last manis I made where I ended up plugging holes with masses of weld or having to plate over some of them #-o
I can really appreciate the work John Volk must put into his manifolds now as it's literally taken me 13hours of solid work to fab and tack together a simple log which doesn't even have any exits yet!
Unfortunately gotta finish off a project for someone else before I can make any more progress, but it's a good start
Instructions?! With a VEMS? I wish!
Will pop it down by cyl 6 I guess
Turbo-Brown
- Boost Junkie
Finally! Some piccies
Here's the turbos and wastegate:
Here's some of the bits for the large turbo's collector:
Here's most of it tacked together:
And from another angle:
Here's the outlet to the little tubby, it's as streamlined as I could make it
And lastly the little HX27 mounted in the car:
Gunni
That thing is going to haul ass.
1bar by 2k?
1bar by 2k?
Turbo-Brown
- Boost Junkie
appletree
cool pics and thats a very nice manifold, must have taken some work to get all the bits to match up, like a big jig saw puzzle.
Turbo-Brown
- Boost Junkie
Cheers dude, yeah it took an age to get the fit right! Thought it was worth the effort this time round rather than just plating over the massive holes my poor joints left like last time.
It's quite satisfying getting the gaps relatively neat and even, makes it easier to weld up too
gareth
you total and utter tart! that looks very nice indeed! bet it took a while to get everything to fit that well
your turbos remind me of the two ronnies for some reason!!!
stuartgallafant
Andy335Touring
That manifold looks the bis !
Yaninnya
Massive job, I'm impressed!Turbo-Brown wrote:Here's the outlet to the little tubby, it's as streamlined as I could make it
One thing: I think that you shoud weld some flaps between turbos (I understand that second turbo flange will be over this one) because the gases from 1,2 and 3 cylinder can blow against gases from 4,5 and 6 cylinder and loosing the energy. I hope you understand what I mean.
Jan
oakey
Brown. Your a very talented bloke. Looks awesome.
Turbo-Brown
- Boost Junkie
Cheers guysYaninnya wrote:Massive job, I'm impressed!Turbo-Brown wrote:Here's the outlet to the little tubby, it's as streamlined as I could make it
Jan
Jan, you're absolutely right, the plan is to see exactly where the larger turbo's outlet from the manifold needs to be and then weld in turning vanes to guide the gasses a bit better towards their respective turbos with the bias being towards the larger one
Yaninnya
The only problem which can became is that in different conditions (rpm, load) you will need different ratio of gasses volume to each turbo. Again I'm afraid that it is not enough clear what I wanted to say(I really needs to learn english!Turbo-Brown wrote:Jan, you're absolutely right, the plan is to see exactly where the larger turbo's outlet from the manifold needs to be and then weld in turning vanes to guide the gasses a bit better towards their respective turbos with the bias being towards the larger one
Jan
d6dph
I love these threads, but at the same time I hate them as I realise how inept I amTurbo-Brown wrote: Loads of techy turbo stuff
Good luck with the build, Like you need it!
Turbo-Brown
- Boost Junkie
Yeah, I think I know what you're sayingYaninnya wrote:The only problem which can became is that in different conditions (rpm, load) you will need different ratio of gasses volume to each turbo. Again I'm afraid that it is not enough clear what I wanted to say(I really needs to learn english!Turbo-Brown wrote:Jan, you're absolutely right, the plan is to see exactly where the larger turbo's outlet from the manifold needs to be and then weld in turning vanes to guide the gasses a bit better towards their respective turbos with the bias being towards the larger one).
Jan
Yaninnya
It looks like I need to wait when more can be seen. I don't know where exactly you are going to fit the flap. Because if it will be just before turbo flange when it will be closed the vanes still will be reflecting the gases into its direction. So you don't know what kind of turbulences it will generate. I'm just affraid that it can reduce the overall manifold flow and efficient of turbos.Turbo-Brown wrote:all flow to the large turbo is blocked at low load to the gas has no option but to spool the small turbo. The butterfly which blocks the flow to the large turbo also serves as wastegate for the small turbo so it should be self regulating.........with luck
Jan
Turbo-Brown
- Boost Junkie
The valve will be situated on the other side of the large collector in a split housing so that I can try to profile the butterfly as much as possible.
When fully open, the valve will locate on the turning vanes so that it just forms part of the internal flow paths of the manifold so with luck the efficiency shouldn't be compromised. This location will also enable the butterfly to disperse heat into the structure of the manifold so that it doesn't cook too quickly.
Yaninnya
I read again the whole thread from the beginning and everything is clear for me now. Yours setup is very close to M57TU2T (535d engine).
Jan
Jan
