Twin Seq. Dry sumping for beginners :D
aauser
Post Thu May 10, 2007 4:57 pm
I would try it in the pink before the brown everytime :)
gareth
Post Thu May 10, 2007 11:39 pm
:D :D :D :D
Turbo-Brown
Boost Junkie
Post Fri May 11, 2007 8:18 am
Another question :
Does the exhaust note come trough the wastege or the turbine wheel at load
The noise must be able to get through the turbine to an extent giving the idle noise (this is why I reckon having two turbines in series will eliminate the need for silencers :D ).
Certainly you hear the exhaust noise ramp up as the wastegates open on boost.
Think I'll go with a full 3" from the turbo back with a straight through silencer and run the WG outlet in 2" pipe through the same silencer at the rear of the car.
Should make it near enough silent at idle and then loud on boost :)
e30_Turbo
Boost Junkie
Post Fri May 11, 2007 3:26 pm
Alex,
Running a screamer isn't at all a issue, either legal wise or noise wise. Have it pocking out under the drivers side arch, save running the pipe all the way to the back.
The screamer does pop, fart and throw flames out but that only happens at full boost so you have the exhaust booming already, although you can still hear the screamer and damn is it cool :cool:
P.s. just windscreen and emmisions need before I'm legal again! BRING IT ON!! :twisted:
Turbo-Brown
Boost Junkie
Post Fri May 11, 2007 5:05 pm
Awesome, you re-made your mani then Mark? :D
Turbo-Brown
Boost Junkie
Post Mon May 14, 2007 5:20 pm
Hooray, £139 for 1m of 1 1/2" pipe, 1m of 2 1/2" pipe and 10No. tight radius 1 1/2" 90degree bends all in S/S grade 304.
Going to steal the T25 flange (which neatly fits the HX27) from the Mi16 and replace that when we need it.
FINALLY the wheels are in motion :D
Ant
Retired Team Member
Retired Team Member
Post Mon May 14, 2007 5:58 pm
Alex, your HX27 have internal W/gate ?
I have one too, 11cm housing for external, just wondering.....
Turbo-Brown
Boost Junkie
Post Mon May 14, 2007 10:29 pm
It does indeed, it's got a bloody hard spring in it too!
Not that I need the internal gate though as the divertor valve does the boost regulation duties for the HX27 so I was just gonna bolt it shut :D
Ant
Retired Team Member
Retired Team Member
Post Tue May 15, 2007 8:27 am
wanna trade ?
Turbo-Brown
Boost Junkie
Post Tue May 15, 2007 2:08 pm
Ooh is it brown-new? Could be tempted, how do I find out what housing mine's got dude? Holset seem to have a bewildering array of possibilities!
I take it that if I undo the V-Band that holds the turbine housing on it'll just pull off over the wheel will it? I've not really taken either turbo apart yet, except the cold side of the H1C, to be amazed at the size of the compressor wheel :D
gareth
Post Tue May 15, 2007 8:17 pm
slight trivia, holset use loadcells that i designed to measure the clamping load on their 'V' band clamps in the QC department ;)
Ant
Retired Team Member
Retired Team Member
Post Tue May 15, 2007 9:19 pm
Alex, she is brand new dude.
you should have an assy number on yours, and the numbers on the casting for the hotside reveal the housing size.
Turbo-Brown
Boost Junkie
Post Wed May 16, 2007 10:15 pm
No idea what the numbers mean, might mean something to you though dude? :D
Assy No. V001000
And cast into the exhaust housing is 89-10410
All very cryptic :lol:
Hmmmm, can we deduce from that that the V-bands should be done up to a specific torque :?
Turbo-Brown
Boost Junkie
Post Wed May 23, 2007 1:53 pm
Ok, here's a question for everyone:
I'm hoping to start the manifold this weekend as I need a break from working on other people's stuff, so should I put my EGT probe in the mani or in the down-pipe?
Cheers!
e30_Turbo
Boost Junkie
Post Wed May 23, 2007 2:23 pm
Turbo-Brown wrote:Ok, here's a question for everyone:
Cheers!
I've read some use only one runner in the manifold but I'd think downpipe would give a better allround reading, what did the instructions say? :D
Gunni
Post Wed May 23, 2007 3:39 pm
As I said on the tech you want the highest reading,
wich is on the least cooled part of the engine, the #6 cyl.
With great challenges comes great engineering.
Gunni
@ 2012 VEMS group buy !!
Turbo-Brown
Boost Junkie
Post Tue May 29, 2007 10:41 pm
Well, I've FINALLY made a start on the fabrication!
Will post some piccies at the weekend when I can borrow a camera but I've spent the whole day just working for myself on the car and have made the log part of the manifold.
I set my mind to doing as good a job as I could and making the joints as tight as possible unlike the last manis I made where I ended up plugging holes with masses of weld or having to plate over some of them #-o
I can really appreciate the work John Volk must put into his manifolds now as it's literally taken me 13hours of solid work to fab and tack together a simple log which doesn't even have any exits yet!
Unfortunately gotta finish off a project for someone else before I can make any more progress, but it's a good start :)
Instructions?! With a VEMS? I wish! :lol:
Will pop it down by cyl 6 I guess :D
Turbo-Brown
Boost Junkie
Post Mon Jun 04, 2007 8:24 am
Finally! Some piccies :D
Here's the turbos and wastegate:
Here's some of the bits for the large turbo's collector:
Here's most of it tacked together:
And from another angle:
Here's the outlet to the little tubby, it's as streamlined as I could make it :D
And lastly the little HX27 mounted in the car:
maxfield
Post Mon Jun 04, 2007 12:21 pm
:cool: :cool:
Gunni
Post Mon Jun 04, 2007 12:51 pm
That thing is going to haul ass.
1bar by 2k?
Gunni
Turbo-Brown
Boost Junkie
Post Mon Jun 04, 2007 1:33 pm
:D Should be possible I hope, might not push it that far though just to keep the thing drivable :)
appletree
Post Mon Jun 04, 2007 3:04 pm
cool pics and thats a very nice manifold, must have taken some work to get all the bits to match up, like a big jig saw puzzle. :D
Turbo-Brown
Boost Junkie
Post Mon Jun 04, 2007 5:04 pm
Cheers dude, yeah it took an age to get the fit right! Thought it was worth the effort this time round rather than just plating over the massive holes my poor joints left like last time.
It's quite satisfying getting the gaps relatively neat and even, makes it easier to weld up too :D
gareth
Post Mon Jun 04, 2007 7:25 pm
you total and utter tart! that looks very nice indeed! bet it took a while to get everything to fit that well :D
your turbos remind me of the two ronnies for some reason!!!
stuartgallafant
Post Mon Jun 04, 2007 9:37 pm
alex, the beast is looking amazing mate!!!
Andy335Touring
Post Mon Jun 04, 2007 9:59 pm
That manifold looks the bis ! :cool:
Yaninnya
Post Mon Jun 04, 2007 10:01 pm
Turbo-Brown wrote:Here's the outlet to the little tubby, it's as streamlined as I could make it :D
Massive job, I'm impressed!
One thing: I think that you shoud weld some flaps between turbos (I understand that second turbo flange will be over this one) because the gases from 1,2 and 3 cylinder can blow against gases from 4,5 and 6 cylinder and loosing the energy. I hope you understand what I mean.
Jan
oakey
Post Mon Jun 04, 2007 10:05 pm
Brown. Your a very talented bloke. Looks awesome.
Turbo-Brown
Boost Junkie
Post Mon Jun 04, 2007 10:30 pm
Jan
Cheers guys :thumb:
Jan, you're absolutely right, the plan is to see exactly where the larger turbo's outlet from the manifold needs to be and then weld in turning vanes to guide the gasses a bit better towards their respective turbos with the bias being towards the larger one :D
Yaninnya
Post Mon Jun 04, 2007 10:46 pm
Turbo-Brown wrote:Jan, you're absolutely right, the plan is to see exactly where the larger turbo's outlet from the manifold needs to be and then weld in turning vanes to guide the gasses a bit better towards their respective turbos with the bias being towards the larger one :D
The only problem which can became is that in different conditions (rpm, load) you will need different ratio of gasses volume to each turbo. Again I'm afraid that it is not enough clear what I wanted to say(I really needs to learn english! :o: ).
Jan
d6dph
Post Mon Jun 04, 2007 10:54 pm
Turbo-Brown wrote: Loads of techy turbo stuff
:bow:
I love these threads, but at the same time I hate them as I realise how inept I am :cry:
Good luck with the build, Like you need it! :D
Turbo-Brown
Boost Junkie
Post Mon Jun 04, 2007 11:03 pm
Jan
Yeah, I think I know what you're saying :D all flow to the large turbo is blocked at low load to the gas has no option but to spool the small turbo. The butterfly which blocks the flow to the large turbo also serves as wastegate for the small turbo so it should be self regulating.........with luck
Yaninnya
Post Mon Jun 04, 2007 11:15 pm
Turbo-Brown wrote:all flow to the large turbo is blocked at low load to the gas has no option but to spool the small turbo. The butterfly which blocks the flow to the large turbo also serves as wastegate for the small turbo so it should be self regulating.........with luck
It looks like I need to wait when more can be seen. I don't know where exactly you are going to fit the flap. Because if it will be just before turbo flange when it will be closed the vanes still will be reflecting the gases into its direction. So you don't know what kind of turbulences it will generate. I'm just affraid that it can reduce the overall manifold flow and efficient of turbos.
Jan
Turbo-Brown
Boost Junkie
Post Tue Jun 05, 2007 8:10 am
The valve will be situated on the other side of the large collector in a split housing so that I can try to profile the butterfly as much as possible.
When fully open, the valve will locate on the turning vanes so that it just forms part of the internal flow paths of the manifold so with luck the efficiency shouldn't be compromised. This location will also enable the butterfly to disperse heat into the structure of the manifold so that it doesn't cook too quickly.
Yaninnya
Post Tue Jun 05, 2007 7:34 pm
I read again the whole thread from the beginning and everything is clear for me now. Yours setup is very close to M57TU2T (535d engine).
Jan
