s50 sump did you s all remove the baffle
irish320i
Post Sat Feb 09, 2008 6:43 pm
the thin sheet in the bottom of the m50 sump and does the pick up just transfer across onto the s50 pump from the m50 pump
Cheers Alan
jaistanley
Post Sat Feb 09, 2008 7:21 pm
If it's a 3.0 litre S50 then the M50 pickup will bolt directly to your oil pump, if its a 3.2 litre engine you'll need the oil pump from an M50b25/S50b30.
As for the baffles: remove any that clash (not sure which ones that is now)
Hope this helps dude.
Jai
irish320i
Post Sat Feb 09, 2008 7:32 pm
thats grand its a 3 litre so just swap the pickup over have a full m50 engine complete bought for conversion but head cracked so ill get the pick up of that
Alan
Al
89 316i s50b30, 00 subaru imperza turbo(gone) 2005 range rover td6,
jaistanley
Post Sun Feb 10, 2008 4:02 pm
Is it from a 5 series? (you need the sump from the 5 series M50)
glenn
Engine Transplant Services
Post Sun Feb 10, 2008 5:55 pm
i didn't have to remove the baffle off the e34 m50b20 sump that i fitted to my s50b32
irish320i
Post Sun Feb 10, 2008 9:56 pm
its a 525 m50 engine im taking the sump off and its going onto a s50b30
Al
ian332isport
Post Sun Feb 10, 2008 11:19 pm
There seems to be a bit of variation in M50 sump design. Some people have to remove it, some don't. It's a while since I did mine, but I don't recall having one fitted.
If it's in the way, then remove it.
Ian.
irish320i
Post Sun Feb 10, 2008 11:36 pm
took the baffle out anyway no harm i suppose gave it a good pressure wash think ill fit it along with the m50 pick up tomorrow must tap it for the return pipe aswell
Alan
Al
