Strange goings on; Temp***FIXED WHOPEEEE******
Widge
Post Sun Jun 05, 2005 10:37 pm
Cheers Brian, my spare sensor is reading 780ish ohms at cold.
The big c101, is that the one under the steering column cowling?
Andy335Touring
Post Sun Jun 05, 2005 11:22 pm
c101 is the round one on the bulk head by the fuse box i think
Widge
Post Sun Jun 05, 2005 11:26 pm
Wiked cheers mate, not going poking around in the dark though! :mad: Might fcuk something up :oops:
Post Sun Jun 05, 2005 11:36 pm
As Andy335 says, the C101 is the big round one on the bulhead, next to the fusebox, where the engine loom plugs into the body loom.
Run the engine up to temp, and measure the sensor resistance then.
780 ohms sounds about right cold.
Toby_Unna
Boost Junkie
Post Mon Jun 06, 2005 12:43 am
as Brian says don't go shorting anything but the correct pin to ground, they are marked with tiny numbers moulded into the black plug plastic but it's not always immediately obvious which number corresponds to which pin.
if you short the the coil feed to ground you'll get some pretty sparks!
i'd guess maybe the fault is in the instrument cluster, the temp and fuel gauges are separate modules which sit on the main board if i remember correctly so possible to get a bad contact. seems to me you'd have to do something pretty brutal to the loom to completely break a wire in it!
Widge
Post Mon Jun 06, 2005 1:03 pm
Right, as I said Toby there is a ferrets nest of wires underneath the inlet all done up with bullets. I have shorted pin 4 and the Temp gauge went to max hot so I have a dodgy connection. Off out to investigate now I can see!
And there was me assuming brkem water pump :roll:
Saved by the Guru again :lol:
Maybe I should rename my car Brian in your honour :wink:
Widge
Post Mon Jun 06, 2005 4:00 pm
Found it, and fixed it!!
One of the wires had corroded where it goes in tho the bullet connector and dropped off. Fixed it, but when I next have the inlet manifold off I'll have to solder and heat shrink them all, there wase barely enough room to crimp them. There was another loose wire that looked like it had come undone it was yellow and brown and in the same bunch as the temp sensor wire. Any ideas Brian?
Thanks for all the help guys really appreciate it :thumb:
craigieeb
Post Mon Jun 06, 2005 5:11 pm
widge did i leave my power bar and my 19" socket at your house mate??????
Widge
Post Mon Jun 06, 2005 5:14 pm
Don't think so, I've just had a look.
Do you have a 2.5 chip?
craigieeb
Post Mon Jun 06, 2005 5:30 pm
crisis over found it :oops:
what sort of chip are we talking about here my good man???
Widge
Post Mon Jun 06, 2005 5:34 pm
in another thread I wrote:Craig, just had a though in the car taking my books back to the library.
You may have already got this covered. But when converting a 320 ---> 325 all you need to change is the ECU chip to tell the fuel injection that it's a 2.5 otherwise it'll be underfuelling. Do you have a 2.5 chip? If not I have the old one from my car at home from before I chipped it which would work, I'll bring it up when I come back on thursday incase you need it.
Cherioo
_________________
You see what I'm getting at?
craigieeb
Post Mon Jun 06, 2005 5:47 pm
ahhh i have that base coverd mate, i have an ECU here mate from a 325i which just replaces the 320i ECU *plug and play styliee*
thanks for the offer tho mate :wink:
Widge
Post Mon Jun 06, 2005 5:48 pm
NO worrie mate good luck with it.
Post Mon Jun 06, 2005 5:50 pm
Oi Widge - you not set off yet? :D
Widge
Post Mon Jun 06, 2005 5:52 pm
Estimated time of departure 6.00pm
Not worth going earlier as I'll catch the team valley rush hour/business traffic by that angel of the north.
Oh it's 5.53 ...............ok I'll be leaving at 6.10pm
Thats 1810hrs to you soldier.
Post Mon Jun 06, 2005 6:02 pm
Roger that
10-4 :thumb:
