Valve cleaning
FIREBREATHER60
Post Mon Jan 28, 2008 4:52 pm
What do ppl think is the best way to clean up valves? is using a wire brush drill attachment tooo corse? also want to try and get the carbon off the stem, any advise would be great
Post Mon Jan 28, 2008 6:49 pm
Caustic soda hot wash, available at a cylinder head specialists, the less effort put in the better IMO 8)
FIREBREATHER60
Post Mon Jan 28, 2008 7:08 pm
Post Mon Jan 28, 2008 7:21 pm
That is caustic soda, but its how its used that does the job
FIREBREATHER60
Post Mon Jan 28, 2008 7:33 pm
Doh ok, machine shop it is then i suppose i do need to get them re seated at some point so might as well do it as one big job.
Aziz
Post Mon Jan 28, 2008 10:35 pm
I'd mix the soda with water in a plastic bucket put some rubber gloves ( Very important)!!
Do NOT handle caustic soda without rubber gloves
Then wash each valve seprately with a scourer. Should come up nice a kleen.
The regrind the valve seat with some grinding paste.
murran
Post Tue Jan 29, 2008 12:27 am
get a drill. put the top of the valve stem in the chuck then spin it round while holding some emery tape on the carbonised bits.........
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
DRIFTBOY
Post Tue Jan 29, 2008 1:26 am
murran wrote:get a drill. put the top of the valve stem in the chuck then spin it round while holding some emery tape on the carbonised bits.........
That's the quickest and easiest way! :D
Just mind out that you avoid the the valve to seat contact surface!
JazzMan
Post Tue Jan 29, 2008 8:32 am
This is what I did as well, the really badly caked stuff on the exhaust valves I used a sharp knife blade in parallel with the surface to get the initial rubbish off, then increasingly finer wet & dry (360 - 1200) and a finish off with metal polish :)
Turbo-Brown
Boost Junkie
Post Tue Jan 29, 2008 1:55 pm
Pleeeeeease buy some goggles if you're dealing with nasty chemicals too!
You only get one pair of eyes but I'm constantly amazed by people's cavalier attitudes to eye protection!
FIREBREATHER60
Post Tue Jan 29, 2008 4:46 pm
Its cool i work in theatre, even though working on my engine at work has nothing to do with work i still have to do risk assesments and h/s so all protective equipment is worn!!
mattyb240
Post Tue Jan 29, 2008 4:51 pm
FIREBREATHER60 wrote:Its cool i work in theatre, even though working on my engine at work has nothing to do with work i still have to do risk assesments and h/s so all protective equipment is worn!!
Risk assessments and health and safety have been the pain of my life lol.
FIREBREATHER60
Post Tue Jan 29, 2008 4:59 pm
tell me about it but when you are surrounded by turns and twirlys (no offence ment to anyone) you have to be that extra bit carefull!! winkeye
Post Tue Jan 29, 2008 7:05 pm
DRIFTBOY wrote: That's the quickest and easiest way! :D
Not really,,,,,, dumping it all in a hot wash and returning 30 mins or so later to minty clean valves is much easier IMO
HairyScreech
Post Tue Jan 29, 2008 7:28 pm
mate of mine down the road normaly deals with nissan engines but aparently he tryed soaking some bits in cillit bang and they have come out awsome. i havent seen them yet but ill let you know.
DRIFTBOY
Post Tue Jan 29, 2008 11:40 pm
I'll race ya!!! winkeye
JazzMan
Post Tue Jan 29, 2008 11:44 pm
^^ wish I thought of / known about that before I spent a day cleaning :lol:
