E30 with E39 M5 Power
glenn
Engine Transplant Services
Post Fri May 20, 2005 5:56 pm
haven't posted for a while, as i had a problem with the engine,
as the engine was warming up, it was starting to run very rich, and was a b*st*rd to keep running, wouldn't tick-over on it's own. think i've sorted it now.
thank's to ian(332i sport) for helping me to obtain a wiring diagram from
the 'states'. something i've been unable to obtain from any dealers or 'speacialists' here.
Glenn how did u arrange ure prop again??? did u use an e30 back end and m5 front??? it may be worth doing the whole lot as an m5 section, after seeing what even my sport has done to the drivetrain.... if not.... may be worth knowcking up a few spares.... LOL
i used the m5 front and center sections and the e30 rear few inch's to join the m3 axle,
i inserted square section into the prop to keep it centralised then welded to two together,
it worked on the 330bhp escort i did.
i will get the rear section made at a prop speacialist once i've road tested the car and i'm happy with it
Do you think the E30 chassis can take 400hp? Never seen one with that amount of power!!
i think the chassis are plenty strong enough,it's down to the individual how much you develop the chassis. 8)
ps imola red, best colour for the e39 m5 IMO
Karan
Post Fri May 20, 2005 6:57 pm
why was it getting rich? i guess uve done the lambda and exhausts then?
glenn
Post Fri May 20, 2005 8:46 pm
it was switching map's in the ecu when it got to a specific temp,
also not enough input from all the sensors.
done the lambda sensors and exhaust gas temp sensor,
5 sensors all together!
finished the exhausts but am going to alter it slightly (to low as it goes under the gearbox crossmember),
wasn't paying enough attention as i was doing the exhausts as my head was thinking about the engine problem
ian332isport
Post Fri May 20, 2005 9:27 pm
Hi Glenn,
I guess you got the software running in the end.
I hope it proves to be useful 8)
Cheers,
Ian.
glenn
Post Sat May 21, 2005 11:22 am
yes ian,
thanks for the help
i've no problems with spanners or welders etc,
but computers, :banghead: :banghead: :cursin: :cursin:
thanks again
foxyboym5
Post Tue May 24, 2005 9:14 pm
glenn wrote:ps imola red, best colour for the e39 m5 IMO
thanks, its a rare colour too! - keep an eye out for July's BMW Car mag :clap:
cheers :P
glenn
Post Thu Jun 02, 2005 6:33 pm
i finished stripping down the loom this week, that's been nearly 4 weeks
cutting.
using all the bmw disc's i had here, and one ian sourced for me, i still couldn't identify every single plug, so thats why it took so long.
i will put some pics up later of the loom before and what i had cut out.
started to install the finished loom into the e30 today, theres not a lot of room behind the dash to squeeze it all in, so i think a fair bit of it will be in the glovebox!!
i am going to re-do the exausts again as i'm not happy with them, they're to low at the cat's (as they're side by side) so i will have to stagger them so i can get them higher in the tunnel.
any way, now that i've done the loom, i can get cracking again.
foxyboym5
Post Thu Jun 02, 2005 6:36 pm
Cheers for the update - im following with interest :mad:
TOURINGDADDY
Post Thu Jun 02, 2005 6:45 pm
This is gonna b 1 ell of a monster :twisted: :twisted:
Karan
Post Thu Jun 02, 2005 7:00 pm
glenn wrote:i finished stripping down the loom this week, that's been nearly 4 weeks
cutting.
dude...... could u possibly cut and posh in the bodywork where the downpipes come down...... ive seen em do it on my conversion in germany...
i may have interpreted u wrong but its an idea...
glenn
Post Thu Jun 02, 2005 7:51 pm
not sure what you mean, karan?
my downpipes are no probs, it's just after the gearbox, the cats are side by side, at the moment, so they are not up in the tunnel high enough, so i'll stagger them to get them higher.
the pics of the loom as promised,
first two are of the loom before i started
the next two are of the wire's that i cut off!!!
TOURINGDADDY
Post Thu Jun 02, 2005 7:55 pm
Not want that lot then
:lol:
SHAKEELE30
Boost Junkie
Post Fri Jun 03, 2005 12:47 pm
been following thread, some mad ass mision, making me jealous. but good luck.. making me think of what i can do to my e30. Not got the technical side like others so just gotta stick to the basics :(
glenn
Post Fri Jun 03, 2005 1:37 pm
SHAKEELE30 wrote:been following thread, some mad ass mision, making me jealous. but good luck.. making me think of what i can do to my e30. Not got the technical side like others so just gotta stick to the basics :(
it comes with age!!! :violin: :lol: :lol:
GermanGorilla
Post Fri Jun 03, 2005 8:14 pm
Hi Glenn,
I see that you are making good progress with the project, I think people forget that M5's are going on for 2 ton in weight, and judging by the amount of wire 'cut' from the loom, your transplant has certainly been on the slimfast.
On the matter of the Cats, just a thought, but as your E30 is pre Cat requirement, why are you bothering with them ?
So long as you can generate suffcient back pressure through the modified exhaust, I do not really see why you need the cats ?
So long as you fit the two exhaust sensors in at the bottom of the left and right banks, then with some remapping to the ECU, I'm sure some guys on the M5Board would help with that, you could remove the cats completely.
You could even leave the 'post' cat exhaust sensors in as a means of protecting the engine from to lean or to rich, the reason they were put there in the first place.
I'm no engine guru, but on the e34 M5 that I still have, the car is so much sweeter without cats. I have never run my E39 M5 without cats, but if racing one [ there too bloody heavy for that] the cats would be the first things to go, regs permitting.
I just think you would remove the space problems on the cats and gain some bhp in the process, not that you really need some though.
Still I hope it has given some food for thought.
All the best for your project,
Regards,
Gorilla.
glenn
Post Fri Jun 03, 2005 8:27 pm
that's definatly food for thought, gorilla
but i just assumed that the engine would n't run properly without them.
but as i have to re-do the exhaust's anyway, i think i'll try it without them and see how it run's
also, the cats make it too quiet, not that i want it too loud but,
it would sound better without!!
jmc330i
Post Fri Jun 03, 2005 8:32 pm
I dont know anything about the E39, but I would have thought it would run fine without the Cats, as along as you have the O2 sensors in place.
Maybe you could fit some smaller silencers in place of the Cats.
James
'91 325i Sport
'93 318i touring 16v
glenn
Post Fri Jun 03, 2005 8:53 pm
thank's james,
i'll do the exhaust's next week,
i'm in the middle of doing the insrument cluster at the moment.
will try and put up a pic of the clocks tomorrow
REEDY
Post Sun Jun 05, 2005 2:17 pm
F*CKIN hell
Awsome, That`ll be 400bhp then?
glenn
Post Sun Jun 05, 2005 4:49 pm
REEDY wrote:F*CKIN hell
when i get the cat's out,also with my modified manifolds i'm estimating around 440 bhp
Jon_Bmw
Dangerous when thinking
Post Sun Jun 05, 2005 9:05 pm
Glenn the only thing is that will it pass an MOT without the cats? Will the emissions not skyrocket??
Or is the MOT not a problem :lol:
ian332isport
Post Sun Jun 05, 2005 9:28 pm
Jon_Bmw wrote:Glenn the only thing is that will it pass an MOT without the cats? Will the emissions not skyrocket??
I'm sure the MOT will be fine.
The car only needs to pass the regulations that were in force when the car was registered, not the current regulations.
My E36 Evo engine without CAT's is way cleaner than my old 2.7 M20 motor.
Ian.
glenn
Post Sun Jun 05, 2005 9:58 pm
got the clocks done today
player6
Post Sun Jun 05, 2005 10:04 pm
looking good
scot 328i with 260bhp
320Touring
Post Mon Jun 06, 2005 3:49 pm
Lovvin the lack of redline on the tacho :cool:
starting to come together now :D
fancy doing my touring? :lol:
Zayyan
Post Mon Jun 06, 2005 3:54 pm
320Touring wrote:Lovvin the lack of redline on the tacho :cool:
Are these the kind of clocks that have a redline that's red and yellow lights rather than printed?
And more lights go off as the engine warms up? 8)
glenn
Post Mon Jun 06, 2005 4:50 pm
yes they are the one's
orange lights start at 4500rpm, then they go out as the engine warms up,
but the last orange stay's lit all the time at 6500rpm, the redline lights up at 7000rpm!! 8)
glenn
Post Mon Jun 06, 2005 7:42 pm
put the clocks in the dash today, only loose as they have to come out a few times yet, just wanted to see how they looked.
started thinking about the look on non-zoners faces when they looked in through the drivers window 8O 8O
TOURINGDADDY
Post Mon Jun 06, 2005 7:48 pm
Dude you are seriously disturbed 8O 8O
but i like it :twisted: :twisted:
Andy325i
Post Mon Jun 06, 2005 10:42 pm
Glenn, that looks amazing! I take my hat off to you!
glenn
Post Tue Jun 07, 2005 7:51 pm
a few more pics,
the radiator is on
took the cats off this afternoon, not started it without them yet,
will have to wait to hear what it's gonna sound like
TOURINGDADDY
Post Tue Jun 07, 2005 7:54 pm
Oh my god
8O 8O :eek: :eek:
Adam318i
Post Tue Jun 07, 2005 8:17 pm
That thing is gona sound like a Tank!! (well, a nice sounding one :D )
I love my Rice!
Davenotouring
Post Tue Jun 07, 2005 8:35 pm
That is fcuking awesome!!!
I'm very jealous! :oops:
BMW 328i Cab - Daily Slag
Geeman
Post Tue Jun 07, 2005 8:43 pm
This project is ace!
I can't believe the amount of work that you've put into this. The end product will be fantastic!
Keep reading it everytime you update it.
My hat is 'trebbly' off to you. (that's 3 times by the way...)
Giles.
