m30 3.5 into e30 325
Bally
Post Sun Jan 20, 2008 9:11 pm
Hi read a bit about this conversion and may try this next year I am going to start getting bits together this summer, not sure but does any one know if it is possible to retain air con(or is there not enough space )
if so should I be looking for a 325 with aircon and retain this or looking for a e34 535 with air con and switch this over. just want to make sure I get the right spec car,
Also looking at some of the engine pics,how do you get the dist cap off once installed as the space between this and rad seems tiny.
thanks
jaffro
Post Sun Jan 20, 2008 9:14 pm
you would have to remove the rad. im in the middle of this swap at the moment :P
Bally
Post Mon Jan 21, 2008 2:14 pm
Hi Jaffro been reading your thread , seems like you are nearly there, your thread has got me thinking about having a go , good luck with it.
any one got any thoughts on tyhe air con , is there enough room or not
thanks
ric325i
Post Mon Jan 21, 2008 2:35 pm
never had to play with aircon. just extra weight imo.
jaffro cant do anything cause i have his engine mounts, muh ah ah ah ahhhhhhh
nickso
Post Mon Jan 21, 2008 3:58 pm
Bally wrote:Hi Jaffro been reading your thread , seems like you are nearly there, your thread has got me thinking about having a go , good luck with it.
thanks
i would think the pump will fit, but as ive never had e30/e34 aircon i dont know about the rest of it.
'88 e30 328i M52 track bint.
Bally
Post Mon Jan 21, 2008 9:43 pm
Thanks Nickso, you have answered my question just needed to know if the pump woud fit around the front , the rest of the bits i have or will have soon, cheers.
corsashmorsa
Post Sat Jan 26, 2008 10:38 pm
there is enough room for the AC pump as i forgot to take mine off and still got my engine in. i only took it off today to make up my mounts. the worst part will be trying to get your ac rad in somwere as theres barely enough space for your normal rad......i have seen a conversion done with AC though so it is possible.
jaffro
Post Sat Jan 26, 2008 10:42 pm
it is very tight. what rad are you useing? as for aircon ive got a cab so not much use really. but it can be done :P
corsashmorsa
Post Sat Jan 26, 2008 11:05 pm
jaffro wrote:it is very tight. what rad are you useing? as for aircon ive got a cab so not much use really. but it can be done :P
you probably didnt aim that at me, but atm i'm not using a rad! any idea what one to go for? i was going to take the grinder to the front pannel to fit a standard e30 rad in and then strengthen what i cut out. although theres probably an easier way to do it....advice welcom!
ric325i
Post Tue Jan 29, 2008 1:17 pm
yeah there is an easier way.
bash the buck head with a very large hammer and put the engine in position 3 (right back as far as you can) then use the e34 if you have it.
but the e28 is better as its thinner.
look for threads under my user name cause i had a long thread with loads on info on it. maybe not the best way to do things but its still all there with loads of pics.
jaffro
Post Tue Jan 29, 2008 1:24 pm
ric325i wrote:yeah there is an easier way.
u best get that big hammer ready for my car haha.
Ziggy
Post Tue Jan 29, 2008 1:31 pm
Remind me how the engine positions are numbered someone? Mine went on the furthest back position that the .de mounts would allow, with no re-shaping of the bulkhead needed...
E28 M535i radiator is the way forward though - so much bigger than the E30 one (nice and thin though) & drops in like it was always meant to be there (mounting holes included).
gooner1
Out humping Reindeer
Post Tue Jan 29, 2008 2:22 pm
Have the very rad needed in the for sale section. Apologies for slight OT. :)
ric325i
Post Wed Jan 30, 2008 3:17 pm
ziggy position 3 is the furthest back- to the back of the car you can get 2.5 and 2 which all go closer to the front of the engine bay.
i think the original b35 was in poistion 1 or 2 as they used a special rad which fit inside the structure at the front.
