fastest thing for 2k?
james318i
Post Sun Jan 13, 2008 8:10 pm
Chris-W wrote:Any hire car, for around 11 weeks :)
so true hahaha :D
Post Sun Jan 13, 2008 8:34 pm
Manual Supra Turbo?
james318i
Post Sun Jan 13, 2008 9:09 pm
my old supra was quick once it was on the turbos but the handling isnt upto much , depends what u wanna do with the car
beemer_jay
Post Sun Jan 13, 2008 9:11 pm
i had a good rover coupe turbo, alot of fun.
never had one thing brake on it so not all are bad. history is important with them though. :)
james318i
Post Sun Jan 13, 2008 9:16 pm
do the rover turbos use the k series motor or the honda engine ?
bodger
Post Sun Jan 13, 2008 10:07 pm
james318i wrote:do the rover turbos use the k series motor or the honda engine ?
T series my friend
Post Mon Jan 14, 2008 9:32 am
SUBARU LEGACY GT 2.0 TWIN TURBO
http://www.pistonheads.co.uk/sales/304616.htm
HairyScreech
Post Mon Jan 14, 2008 6:20 pm
seconded on the legacy, look like a hurse but there the fastest stiff shifter you will see, especialy if you get a b-spec.
afromaan
Post Tue Jan 22, 2008 10:19 pm
forget tthe lot of em find urself a mitsi evo 2 and FLY!
BreadBin
Post Tue Jan 22, 2008 10:21 pm
200sx - without a doubt
Humph
touringsport
Post Tue Jan 22, 2008 10:25 pm
please dont shoot me, but,
Renault 5 GTturbo. I had one for over a year, and it didnt even blow up once!!
Something quite perverse about spinning 14" front wheels at f**k-knows-what-mph :mad: :mad:
ALL WORK AND NO PLAY MAKES JACK A DULL BOY ALL WORK AND NO PLAY MAKES JACK A DULL BOY ALL WORK AND NO PLAY MAKES JACK A DULL BOY
Hakkera
Post Wed Jan 23, 2008 12:33 am
BANG!
Has to be the 200SX, however be damn careful when driving round a roundabout or turning on a junction. When the turbo cuts in at 3000RPM, you can very easily find yourself pointing where you were coming from...
nzracer
Post Wed Jan 23, 2008 5:39 pm
DanThe wrote:Me running.
Put the 2k in my hand and I will demonstrate :)
LMFO :D winkeye
fuzzy
He who sleeps with "Gingers"
Post Sat Jan 26, 2008 2:27 pm
ill sell you my engine for £2000. then you can put it in anything you want winkeye
Morat
Post Sun Jan 27, 2008 10:36 pm
I've got a 16valve turbo Fiat Coupe... had it for nearly 10 years now. Love it.
Gotta watch the cambelts, but thats true of everything really. They last longer on a 20V but cost more to replace (engine out according to FIAT, specialist indies cut a small hole in the inner wing).
Both engines are good for reliability only if they are scrupulously serviced. 20V like a bit of oil, and can crack their exhaust manifolds. Most will have been replaced by now.
16Valvers don't drink oil but can munch their cams if they don't get regular oil changes. Check the oil pressure gauge like a hawk. Anything less than 1.2bar on a hot (90deg water temp, its calibrated) idle and RUN away.
Its the minor bits that let go. Aircon, central locking. Otherwise its pretty similar to an E30/any older car. Wishbones, Brake lines and other wear and tear items. Geraboxes are pretty solid. Rust isn't that scary but they can go behind the front arches and check round the boot seals.
20VT is faster as standard, both can be tuned way beyond anything sensible in FWD. 20V tuning is pretty specialist, 16V tuning goes down the relatively well know Integrale routes. Don't dent the bonnet - they are NLA from Fiat.
google FCCUK and look at their forums.
bodger
Post Mon Jan 28, 2008 12:49 am
:burn:
e36boy
Post Mon Jan 28, 2008 10:29 pm
Blitz wrote:SUBARU LEGACY GT 2.0 TWIN TURBO
I agree with Blitz on this................quick car and you can make them look mean :twisted:
sunnysr
Post Mon Jan 28, 2008 11:09 pm
a subaru impreza wrx
nissan pulsar
e36 325
tomtomiS
Post Mon Jan 28, 2008 11:22 pm
touringsport wrote:please dont shoot me, but,
mine used to do that a lot, tho mine had the standard 13" alloys, was quite a fun car but so unreliable, u would need £2k spare just in case things went pop!
