Thanks, Goosie
expansion tank cleaning?
goosiegander
- Zonegoose
Best product/method for making the coolant expansion/window washer reservoir tanks look like new again?
Thanks, Goosie
Thanks, Goosie
goosiegander
- Zonegoose
fair... but i do actually like cleaning things up, call me a madman...
goosiegander
- Zonegoose
cool ill give that a try!
goosiegander
- Zonegoose
i just did
lol!
march109
- Contact:
For stubborn marks I like the citrus bbq cleaner from the same people that do WD40, comes in the same sort of can, but in lime green. Dissolves any crap and cleans my engine bay and bbq great.
Though I'd rather buy a new one.
- Contact:
They are approx £30 a piece new, I bought an expansion tank, but I couldnt part with the cash for a washer bottle as I knew I would forget to top the screen cleaner up and it would go mouldy again.
I think I filled mine with hot water and toilet cleaner/limescale remover overnight, worked well but it has since had several bouts of mould induced leprosy
beardymat
- Location: sheffield, city of steel, and rust apparently
i fitted new bottles to mine so you can imagine my dissapointment when the engine repeatedly filled the expansion bottle with murky brown water despite numerous flushings with clean water and a proper engine flush plus 3 lots of fresh anti freeze
probably had something to do with the car standing for @ two years with no rad and a dribble of water still in the block which i found when changing the timing belt and water pump in prep for recomissioning the engine. which id found the thread about the drain plug on the block a little earlier.
sweet im going to get 2 new bottles then. becuase my coolant isnt murky and brown as my engine is rebuilt.new water pipes etc. might throw a new rad in just for good measure.
cant say ive evey had mold in my washer bottles either
I've cleaned mine up using sea sand and soapy solution. Came out like new.
Regards
Clyde
Go everywhere sideways...
Clyde
gareth
TFR did the job on my cooling system. 2 years on after a cracked head and it's still completely clear! do this before cleaning the tank!
Are the water pump bearings exposed to the coolant on E30 engines?
Just curious as My little Suzuki SJ410 blew a head gasket a year or so ago and i'm still getting manky gloop out the expansion tank, because i've always been scared to put anything nasty in there to clean it all out because i put a new water pump in and was always scared of degreasing any bearings etc.
gareth
nope. they're sealed. usually when the seals fail, the bearings fail just afterwards. a giveaway sign is a noisy pump that's weeping coolant throigh the front.
cliffybabe
- Powered by Nelly
mine went in the dish washer (whilst mum was out) and it come up like new
e34Murphy
- Contact:
i will be giving the m30 headertank a clean soon as not only have i got some mirky bornw coolant now (not been change in a year or so i doubt) and the bottle is so dirty you cant see where the coolant is on the min and max indicator
Ive been threatening this on the E-dirtysix for a while now but i blew radiator to hell last week so now would seem like a good time....
goosiegander
- Zonegoose
finally bit the bullit and purchased a new expansion tank from bmw
