engine
jb81
ive got a 320ise (89f), and looking for more power any good tips, or am i just better off fitting a 325 engine thanks for any replys
320Touring
you can get about 10hp out of it by fitting a zone wild chip from ant on this forum (chips@e30zone.co.uk) for Ԛ£55
and if you fit a Big Bore Throttle Body and a K&N panel filter you should have a useful 145ish BHP
you can get the BBTB from the zone too Ԛ£120 exchange if i remeber correctly
Zayyan
If you're old enough for the insurance to be "favourable".....get a 2.5
And then do the mods 320Touring suggests...
320Touring
dude, dont! 2.5 conversion is laaameZayyan wrote:If you're old enough for the insurance to be "favourable".....get a 2.5
the mods i've mentioned are really 'bolt on' so you can try them and change them if you dont like them...
the 2.5 conversion is a great way of getting 40bhp more, but its a 'touch' more involved..
Zayyan
Rubbish! Two people can do it in a day! I asked Karan who's probably done the most engine swaps outta anyone on here
Just cos you've got a measely 2-litre Neil
Though I can't talk....gonna be in a 1.4 for a few weeks from tomorrow
Wilson
I assume the 2.5 into 2.0 litre doesn't involve changing anything else other than obviously inlet... if not then its fairly easy, providing you got a crane etc, I've never worked on BMW before I got mine, and me and two mates fitted new engine in a day!
Wilson
My mate has a 320, and I've got a spare 325 tb, is it worth putting on his, bearing in mind I'll give it to him free of charge!
Marc
Marc
Karan
yeh it really is simple to upgrade to 2.5..... dont waste ure time and money modding ure 320.....for a few bhp
2 ppl can do it in a day easily.2 days no problem
only thing is u need to change the prop as they are different and just whack all the 2.5 stuff in with 2.5 loom and plug and play!
Karan
Karan
Karan
oh and ive only done a few swaps..... but once uve done one, uve done em all really.....Zayyan wrote:Rubbish! Two people can do it in a day! I asked Karan who's probably done the most engine swaps outta anyone on here
jb81
ill have a good think about both, but its the flat spot up to 4000rpm thats pissing me of, if a chip and fillter will sort that out then ill down that road, thanks for the help lads
Andy_magic
A 2.7 conversion will sort that outbut its the flat spot up to 4000rpm thats pissing me of
jb81
would be nice a 2.7 but money is a big issue
- Homo Hair
dont bother with the 2.0
2.5 conversion is a days work
- Homo Hair
and better results
jb81
i have no problem with fitting the 2.5 engine, its just do i need a 2.5, all i wont is to make it pick up a bit faster, but then agen a 2.5 with the same mods sounds good to, ill just have to keep checking my pigy bank and see wat i can do
M5pilot
Sell the car and buy a 325i............easiest option unless your shell is immaculate.
Changing an engine is not hard. If you have your own garage then its very very easy.
Ive done two now and as long as your organiased its not difficult.
jb81
my shell is tidy with little rust the car is the same as dazleeds car, the right colour as well and i dont want to sell the car, but i do see were your coming from, i think i will tri a chip and panel filter and if i am not happy with it then ill think more about the 2.5, thanks for all the replys
- Homo Hair
panel filter will do nothing..
what power do you get from a pretty standard 2.7 conversion? I always look at the 2.7 conversion as a bit of a halfway house. If I pop my motor then I think I would just go straight to 3.5, although I do like the thought of the 24V M50.
Karan
3.5 is cheap and cheerful option...E30BeemerLad wrote:what power do you get from a pretty standard 2.7 conversion? I always look at the 2.7 conversion as a bit of a halfway house. If I pop my motor then I think I would just go straight to 3.5, although I do like the thought of the 24V M50.
a good 2.7 will be slightly quicker than a m50 and feel torquier and quicker also.
2.7 is not about top bhp figures but torque... much like the 3.5#
id say go 3.5!!!!
cheers Karan - I like the way you think fella
"no replacement for displacement" eh!
Mind you, 3.5 conversion means i'm into different box and prop etc doesn't it.
jb81
i now the panel filter wont give extra bhp but it will help it rev a bit better witch should help it pick up a bit better and be a bit more smoother
See jhonno's last post.
