325i 1989 h reg idle problem
540itouring
Hi , my work mate has a 325 touring M20 engine (E30 H reg) whch due to a cracked head has had a new head , cam , belts etc. The engine now runs ok but on a cold stat the idle hunts between 250 and 800 and does cut out. When the engine has run for a few minutes the idle is stable but after a while the idle goes upto about 1200. Apart from this the engine is stable and drive well. I would think this could be a mixture , or idle speed control valve fault etc but is stable after warm up apart from high idle. Please can any one help on this problem . Thanks
Andy_magic
HI, have a look here. It should answer all your questions.
http://www.e30zone.co.uk/modules.php?na ... ic&p=81184
Don't forget to vote.
Zayyan
For future reference H reg ran from 1st August 1990 'til 31st July 1991, so yours is either a '90 or '91 car and not an '89
Not really relevant but just thought I'd point it out
320Touring
Andy's guide is excellent! the pipes etc are cheap from stealers too, so if one is gone then its not too bad!
The Idle Control Valve can be cleaned out to aid it-all covered in the guide
GOOD LUCK!!!
GOOD LUCK!!!
Andy_magic
Cheers mate!
Beowolf325iT
Just a thought, but do you hear any hissing sounds around the intake manifold? I recently had a very somilar problem (with dodgy cold start & variable idle (400-1100 rpm)) on my '89 e30 Touring and it turned out to be a deteriorated intake manifold gasket(s). I initially thought ICV failing, etc, etc but it was a gasket problem along. I've since heard these gaskets deteriorate over time
Cheers,
Jeff
Cheers,
Jeff
Andy_magic
Good point.
Beowolf, you should sort your avatar out before a mod see's it. Nice looking tourer!
JAMZ
Wow..
split screens?
avatar alert
lol
split screens?
lol
H-M3
ifyou manage to sort this out than please let me know, as i am having the exact same problem and my fuel consumption is quite poor at the moment.540itouring wrote:Hi , my work mate has a 325 touring M20 engine (E30 H reg) whch due to a cracked head has had a new head , cam , belts etc. The engine now runs ok but on a cold stat the idle hunts between 250 and 800 and does cut out. When the engine has run for a few minutes the idle is stable but after a while the idle goes upto about 1200. Apart from this the engine is stable and drive well. I would think this could be a mixture , or idle speed control valve fault etc but is stable after warm up apart from high idle. Please can any one help on this problem . Thanks
H-M3
hi mate what do you mean by the intake manifold gasket? is not the exhaust manifold gasket? Coz I have changed that one.Beowolf325iT wrote:Just a thought, but do you hear any hissing sounds around the intake manifold? I recently had a very somilar problem (with dodgy cold start & variable idle (400-1100 rpm)) on my '89 e30 Touring and it turned out to be a deteriorated intake manifold gasket(s). I initially thought ICV failing, etc, etc but it was a gasket problem along. I've since heard these gaskets deteriorate over time
Cheers,
Jeff
cheers
Andy_magic
Theres one big gasket between the throttle body and the inlet manifold and then six smaller ones between the inlet manifold and the head.
