my speedometer is acting strange
alex-e30
Tue Dec 04, 2007 1:43 am
when i accelarate the speedo reads 0 mph, then when i take my foot off the accelarater the speedo gives the true reading, have i got a dodgy earth or is the speedo cable on its way out? :eek:
thanks
this is my beemer, there are many like it but this ones mine
(OO=[][]=OO)
SPADGE
Tue Dec 04, 2007 7:48 am
They don't have a cable they are elcetronic.
What you describe is a common problem.
The sensor for the speedo is attached to the diff and the wires going to it go brittle.
The best thing to do is to replace the wire (2 core) as far back as you can go which should be around 300mm.
bigun
Tue Dec 04, 2007 8:26 am
^^^^^^^as above just done mine
junkjimmy
Tue Dec 04, 2007 11:15 am
Dude you can buy replacment conectors from Bmw with a good length of wire
Andy335Touring
Tue Dec 04, 2007 7:06 pm
junkjimmy wrote:Dude you can buy replacment conectors from Bmw with a good length of wire
I'm just about to do this so i've got the part # below
Plug housing 61 13 1 378 417
2 x cable socket 61 13 1 382 246
alex-e30
Thu Dec 06, 2007 1:09 am
could this problem occur if my diff was on its way out because mine is :cry:
(OO=[][]=OO)
Thu Dec 06, 2007 9:10 am
Nothing to do with failing diffs. You can use a length of wire and plug from the headlamps of a scrap E30 if you're too tight to buy new.
alex-e30
Thu Dec 06, 2007 12:01 pm
il just buy new its easier :wink:
(OO=[][]=OO)
