My M5
SPADGE
Post Sun Dec 02, 2007 4:20 pm
Just thought i'd post a quick pic of it.
More to follow when i've had a chance and some decent weather to do a few jobs and clean it :D
c76jon
Post Sun Dec 02, 2007 4:37 pm
Nice car
Hope you got deep pockets!!
Brilliant car to drive
enjoy it
jon
SPADGE
Post Sun Dec 02, 2007 4:53 pm
c76jon wrote:Nice car
enjoy it
jon
Thanks :D
I ran/built/uprated Cossies for years so i doubt i'll need deeper pockets than i did for that lol :)
It'll only get used for bimbling about so i'm sure it'll be fine.
Post Sun Dec 02, 2007 5:07 pm
Very nice. Love the colour and it's the right model. Spot on mate. This a keeper?
c76jon
Post Sun Dec 02, 2007 5:08 pm
depends to what degree you played with cozzies..........
my last rs500 engine stood me 23k :eek: :eek:
these m5s are an expensivecar to run and by that i mean properly
do you have EDC ?
they are just at that age where MAFS,suspension,gearboxes,diffs start to play up
how many miles has it done?
does your cold start pump kickin to wake the neighbours??
SPADGE
Post Sun Dec 02, 2007 5:15 pm
c76jon wrote:depends to what degree you played with cozzies..........
do you have EDC ?
Not sure if i have EDC or not its a 1993 3.8 if that helps?
What does this cold start pump sound like? I do get a bit of a weird noise when it starts from cold which goes away after its been running for a minute or two :? Should i be worried?
Its done loads of miles but has had a fortune spent on it in the last year or two inc the 4.5k engine rebuild 40k ago.
c76jon
Post Sun Dec 02, 2007 5:30 pm
no you shouldnt be worried
nice that its still working
it injects fresh air into exhaust gases so it would pass usa emissions
they are very rich running especially when cold and it is supposed to stop after a short while
mines a 1993 3.8 too.
if things are correct and you have edc then you should have a wider wheel at rear but after all these years that isnt the best pointer
EDC is electronic damper control
brilliant when it works but 2k just for struts when they leak
right hand side of dash cluster there will be a switch if you have it with "s" and "p" on it
you may well have got a good en
the engine build is a nice thing
a bare head is 4k
jon
E30Mark
Post Sun Dec 02, 2007 5:33 pm
Saw that on ebay, Eddie Stobart's car !! 8)
PM for details
Bob_S
Post Sun Dec 02, 2007 5:58 pm
an m car is not for bimbling in!! that's sacrilage
Bollocks to this 24v scrap!
SPADGE
Post Sun Dec 02, 2007 6:07 pm
Bob_S wrote:an m car is not for bimbling in!! that's sacrilage
You havn't seen the way i 'bimble' Bob :D
SPADGE
Post Sun Dec 02, 2007 6:10 pm
c76jon wrote:no you shouldnt be worried
a bare head is 4k
jon
No EDC then mate which i'm pleased about :D
Is it possible to buy a new set of Bilsteins or the like without paying 'mortgage' money then?
The things that need attention straight away are the viscous coupling which is fecked and it seems a bit 'wooly' at the front although going from the bills most things up front have been replaced.
c76jon
Post Sun Dec 02, 2007 6:13 pm
iam pretty sure they are not silly money
springs may be fecked
whats idle like??
any hesitaion on acceleration?
whats light throttle like??
jon
SPADGE
Post Sun Dec 02, 2007 6:17 pm
c76jon wrote:iam pretty sure they are not silly money
whats idle like??
jon
I have seen at least 2 bills for rear springs after broken ones were discovered so i'm guessing these are a weak point?
Idle is pretty good although there is a very slight miss but i suspect it needs plugs.
No real hesitation on acceleration but it doesn't seem to have a lot at low rpm. Over about 4k and especialy between 5 and 6k it pulls like a train 8)
Light throttle seems ok too.
c76jon
Post Sun Dec 02, 2007 6:45 pm
valve clearences are absolutely vital on these cars and play a big part in how they run
they eat plugs and my advice is use oem spec
at 4k they pull real hard
mafs wear out over time (350ish from bosch)
oxygen sensor also plays a big part in idle and smoothness
check its had one of them?? (75 quid so its not a biggy)
main problem is wires to sensor underneath go brittle
same goes for water temp sensor which is on left hand side of engine on pipe that runs up lhs of engine(as you look at car from front) the sensor is blue
the wiring to this sensor is known to go very brittle and break
they also run coil packs on top of each plug and these can fail or start to break down (50 quid ish)
jon
ask me how i know prices!!!
gcorky
Boost Junkie
Post Sun Dec 02, 2007 6:48 pm
very nice spadge.you into e34s now then...seem to get a few. :D
525 sport
gcorky
Boost Junkie
Post Sun Dec 02, 2007 6:50 pm
525 sport
Bob_S
Post Sun Dec 02, 2007 6:54 pm
note on the valve clearances..
they are vital.. also the tool is rare as rocking horse poo poo or you can get one from BMW.. £112
Post Sun Dec 02, 2007 7:08 pm
All 3.8s have EDC (extremely distressing cost !) suspension. The optional nurburgring pack gives you wider rear wheels, thicker rear anti roll bar and a dash mounted switch. Tourings had the wider rears and fatter roll bar as standard. The switch can be retrofitted easily to any 3.8 as the wiring is already there.
Jon, hows the turd going ? have you washed it yet ? :)
maxfield
Post Sun Dec 02, 2007 7:10 pm
Rather nice Spadge.
S38's take well to F/I winkeye winkeye
Any plans?
rebelcruiser
Post Sun Dec 02, 2007 9:03 pm
:drool: m5 good choice looks very nice in that colour :cool:
SPADGE
Post Sun Dec 02, 2007 9:06 pm
Cheers for the info Jon i'll give it good going over as soon as we get some better weather.
I might even run it down to BMW to get them to run a diagnostic on it just to see if anything is on its way out.
gcorky - I've always had a thing about e34's mate and have owned loads of them :D
Bob - I'll see what BMW say about the valve clearances when i drop it down to them but i'll do them myself.
Pete - I'll see if i can find this switch somewhere but i'm not sure i want to fit it and find the suspension is fecked lol :mad:
Max - My only plans at the moment are to keep both it and my bank account in the black so it can stay as is for now :) What do you mean by F/I?
maxfield
Post Sun Dec 02, 2007 9:11 pm
With all your years in Cossie's I would of expected you to do something with a proper engine :)
SPADGE
Post Sun Dec 02, 2007 9:12 pm
maxfield wrote:With all your years in Cossie's I would of expected you to do something with a proper engine :)
Forced Induction yeah :D
No i'm leaving this thing well alone!
fuzzy
He who sleeps with "Gingers"
Post Sun Dec 02, 2007 9:23 pm
nice car mate.should be a much nicer beast to drive than a rattly old ford. ive also had thoughts on these but was considering the touring model :cool:
c76jon
Post Sun Dec 02, 2007 10:06 pm
pacerpete wrote:All 3.8s have EDC (extremely distressing cost !) suspension. The optional nurburgring pack gives you wider rear wheels, thicker rear anti roll bar and a dash mounted switch. Tourings had the wider rears and fatter roll bar as standard. The switch can be retrofitted easily to any 3.8 as the wiring is already there.
its a proper car pete
slave cylinder went and i replaced it
now the master cylinder has decided to self destruct in sympathy
oxy sensor packed up
love it to bits
running really really well
jon
NL-BMW
Post Sun Dec 02, 2007 10:11 pm
NICE :thumb:
bloom_meister
Post Tue Dec 04, 2007 12:23 pm
LMAO
DieselMeister
Post Tue Dec 04, 2007 7:48 pm
Nice work Spadge - top choice of car 8)
SPADGE
Post Wed Dec 05, 2007 11:10 am
c76jon wrote: does your cold start pump kickin to wake the neighbours??
Can this be disconnected if its not pariculaly needed?
It fires up about 30 secs after you start the engine from cold and goes off about 2 mins later and is loud :?
If it can't be disconnected is it an expensive item and is replacement a ball-ache??
Cheers Spadge..
blitz877
AKA ajm-e30
Post Wed Dec 05, 2007 11:13 am
nice m5 you have there
Onz
Post Sat Dec 08, 2007 1:29 pm
really nice motor mate :D
