More to follow when i've had a chance and some decent weather to do a few jobs and clean it
Thanksc76jon wrote:Nice car
Hope you got deep pockets!!
Brilliant car to drive
enjoy it
jon
Not sure if i have EDC or not its a 1993 3.8 if that helps?c76jon wrote:depends to what degree you played with cozzies..........
my last rs500 engine stood me 23k![]()
these m5s are an expensivecar to run and by that i mean properly
do you have EDC ?
they are just at that age where MAFS,suspension,gearboxes,diffs start to play up
how many miles has it done?
does your cold start pump kickin to wake the neighbours??
c76jon wrote:no you shouldnt be worried
nice that its still working
it injects fresh air into exhaust gases so it would pass usa emissions
they are very rich running especially when cold and it is supposed to stop after a short while
mines a 1993 3.8 too.
if things are correct and you have edc then you should have a wider wheel at rear but after all these years that isnt the best pointer
EDC is electronic damper control
brilliant when it works but 2k just for struts when they leak
right hand side of dash cluster there will be a switch if you have it with "s" and "p" on it
you may well have got a good en
the engine build is a nice thing
a bare head is 4k
jon
I have seen at least 2 bills for rear springs after broken ones were discovered so i'm guessing these are a weak point?c76jon wrote:iam pretty sure they are not silly money
springs may be fecked
whats idle like??
any hesitaion on acceleration?
whats light throttle like??
jon
its a proper car petepacerpete wrote:All 3.8s have EDC (extremely distressing cost !) suspension. The optional nurburgring pack gives you wider rear wheels, thicker rear anti roll bar and a dash mounted switch. Tourings had the wider rears and fatter roll bar as standard. The switch can be retrofitted easily to any 3.8 as the wiring is already there.
Jon, hows the turd going ? have you washed it yet ?
LMAOpacerpete wrote:All 3.8s have EDC (extremely distressing cost !) suspension.
Can this be disconnected if its not pariculaly needed?c76jon wrote: does your cold start pump kickin to wake the neighbours??
