more newbie questions
AndyBird
getting my new E30 piccies soon, however the orange light is on on the service bit. if i service the car how do i turn this off?
Davenotouring
You can buy a 'Draper' tool or similar from eBay to switch them off.
There are 'other' ways to do it, but I wouldn't chance it.
Make sure you do service it!
BMW 328i Cab - Daily Slag
smithy318i
Don't buy a reset tool. They are a RIP OFF.
all you need is a paper clip. (im serious)...look.
http://www.bmwe30.net/cgi-bin/datacgi/d ... Section=02
mikw
smithy 318i, have you tried this yourself ?. seems an easy fix
smithy318i
Yes.
twice, without a problem.
1 on early type (316)
1 on late type (318i)
You can buy a tool if you want, but it's a waste of money (IMO)
Simply short the two pins out, then switch the ignition on until the lights go out. (AFTER YOU SERVICED IT)
16azev_needed_for_my_e30
All i can say is thanks very much boyz - just re-set my service lights - don't worry i did the service the other month
AndyBird
i can honestly say this is the best board ive been on for speed and quality of info
cheers all
cheers all
mikw
Thanks for the testimonial lads,
Will try
Will try
naylor04
It says you should use a "fused wire" , how do i make one of them then ?
smithy318i
Just use a bit of wire with an in-line fuse (low value)
Simon
Make sure you guys get the right pins if using the fused wire method, get it wrong and it could be costly!
I wouldn't call the reset tool a rip-off though, I paid Ԛ£15 for mine about 5 years ago, and they're still available for that price, and I've lost count of the number of times I've used it, for my own, and others cars!
There is absolutely no need to buy a tool or use a fused wire.
Pin 7 sits pretty much on its own, and is difficult to confuse with any other pin. Just connect a piece of wire from pin 7 to the car body or engine (throttle cable bracket is handy), and turn the ignition on till the lights go out.
