Record of 318iS recalls?
tomze30
Post Sun Nov 25, 2007 11:29 am
Did BMW recall the 318iS when the profile gasket issues arose?
And if so, will there still be a record of which cars were fixed by that route?
Heyho
Post Sun Nov 25, 2007 8:45 pm
I don't think that there was a recall.
If it happened under warranty, then obviously it would be done, but no recall.
kam-325i
Post Sun Nov 25, 2007 10:11 pm
The only recall ive seen for the E30 was the one for the expansion cap.
tomze30
Post Mon Nov 26, 2007 9:05 am
kam-325i wrote:The only recall ive seen for the E30 was the one for the expansion cap.
What was the problem?
Sjoerd320i
Post Mon Nov 26, 2007 11:15 am
they couldn't hande the presure in the cooling system, it should say 140 on the bottom of the cap then youo have the right one
iDreamBeemer
Post Mon Nov 26, 2007 11:37 am
There was a recall for the iS but I could not tell you what the fault was. Only reason I know was I had a BMW dealer stamp in my service history specifically for a recall in a small booklet.
You could PM Gussy as he bought the car off me and he could look in the paperwork (if he is feeling nice) and tell you what it says!
tomze30
Post Mon Nov 26, 2007 1:40 pm
iDreamBeemer wrote: You could PM Gussy as he bought the car off me and he could look in the paperwork (if he is feeling nice) and tell you what it says!
There's a Gus and a Gus1 ... which one is he?
iDreamBeemer
Post Mon Nov 26, 2007 4:30 pm
Neither. It is Gussy!
E30Mark
Post Mon Nov 26, 2007 4:38 pm
http://www.e30zone.net/modules.php?name ... ile&u=8423 :cool:
PM for details
tomze30
Post Mon Nov 26, 2007 4:45 pm
Cheers Mark, just found it and pm'ed :D
Gussy
Post Mon Nov 26, 2007 5:47 pm
Just trawled though all the history there.
Yep, it was for the expansion cap alright.
tomze30
Post Mon Nov 26, 2007 7:25 pm
Question answered, Thanks guys.
stuartgallafant
Post Mon Nov 26, 2007 7:34 pm
There were actually 2 recalls for the iS. 1 for the expansion cap and the second for the heater plate located at the front of the throttle body.
As far as i am aware, the profile gaskets were not a recall. When i put my chassis number in from my iS on the viewdata computer at work, it tells me that both recalls have been carried out
tomze30
Post Mon Nov 26, 2007 7:48 pm
The plot thickens. I'll have to see if I can persuade the local stealer to check mine. :?
kam-325i
Post Mon Nov 26, 2007 10:43 pm
tomze30 wrote:The plot thickens. I'll have to see if I can persuade the local stealer to check mine. :?
I phoned BMW customer service's to check mine.....
tomze30
Post Tue Nov 27, 2007 7:47 am
kam-325i wrote:I phoned BMW customer service's to check mine.....
Was that at your local dealer or a central number?
powelly
Post Tue Nov 27, 2007 2:44 pm
I took a look at the recall info we have in our library, the only E30 related one I could find was this. As mentioned above it`s just the exapnsion cap one.
RECALL DATE (REFERENCE): 16/02/1998 (R1997068)
MODEL: Old Shape 3 Series (E30)
CONCERN: Overloading of coolant circuit.
DESCRIPTION: Overloading may occur in the coolant circuit which encompasses the engine, radiator and heat exchanger. Should the heater heat exchanger be affected, hot water and steam may suddenly escape into the vehicle interior. This could seriously impair visibility through the windscreen. Injuries to the feet and lower legs may also result.
ACTION: The affected vehicles are being recalled to BMW dealers for the fitment of a replacement radiator cap.
VINS: Various
BUILD DATES: 1982 to 1994
NUMBERS INVOLVED: 16100
Image Le Mans Classic 2006
Heyho
Post Wed Nov 28, 2007 6:21 pm
You can check for outstanding recalls here:
http://www.vosa.gov.uk/vosa/apps/recalls/default.asp
And as for the rad cap recall, who's ever heard of the rad or heater matrix exploding before one of the rubber hoses?
Or was it just a ploy to get 12 years worth Beemers back into the dealerships?
Chris-W
Post Wed Nov 28, 2007 6:27 pm
As I remember BMW never officially recognised a weakness / fault with the profile gasket on E30 M42s.
