turbo's????????
treeseries
Post Mon Nov 26, 2007 9:05 pm
hi every1 im looking at gettin a turbo or in fact 2. for my e32 750 lump but i dont know anythin about turbos. i know a few people have truck turbos and a few dont. i dont understand t3's or t75's? whats the differance or whats best for big power outputs and torque. should i go for lorry turbo or car? any info would be great.
Gunni
Post Tue Nov 27, 2007 12:39 am
your about million miles from knowing the answer.
And nobody will be able to answer you in a simple thread.
You need to read ALOT on turbocharging before you even think about anything more.
In honesty. 2 x HX30´s would rock on a M70.
With great challenges comes great engineering.
Gunni
@ 2012 VEMS group buy !!
Morat
Post Tue Nov 27, 2007 11:28 am
Your best bet is to go to an expert in the field and throw money at him. On the other hand, if you're interested in learning to do it all for yourself you're going to need to do the reading that Gunni talks about. You'll need to learn about Engine Management systems as well.
treeseries
Post Tue Nov 27, 2007 8:56 pm
Holset HX35
Designed primarily for 6 cylinder engines of 5.0 to 6.5 litre capacity, the Holset HX35 turbocharger has higher flow aerodynamics capable of providing up to 0.46 kg/s at 3.0:1 pressure ratio.
taken from holset website surely 2 of these would be ideal with mine bein a v12
fuzzy
He who sleeps with "Gingers"
Post Tue Nov 27, 2007 9:16 pm
wouldnt a twin turbo set up using 2 different size turbos be more usable? a smaller turbo to get you going from low revs before the bigger turbo kicks in to take you to the top end.
in my experience a quicker spinning low down acceleration based turbo is more usable everyday than one that doesnt start spinning until 3000rpm.
maxfield
Post Tue Nov 27, 2007 9:19 pm
Yes but fuzzy we're talking to different banks here.
It would be good on a Inline engine. But I cant see it being on a V12.
treeseries
Post Tue Nov 27, 2007 9:23 pm
hi im not to sure about turbos but i'll take on the smaller turbo idea the only thing is what i know of turbos they go into the airflow between the airfilter and inlet manifold i belive, wouldnt it be easier to just run two turbos the same size for each bank of cylinders bearin in mind that a twin turbo 5ltr v12 wont be my daily runner.
treeseries
Post Tue Nov 27, 2007 9:24 pm
p.s thats twice i've agreed with maxfield i should ge that seen too
maxfield
Post Tue Nov 27, 2007 9:27 pm
treeseries wrote:p.s thats twice i've agreed with maxfield i should ge that seen too
fuzzy
Post Tue Nov 27, 2007 10:07 pm
maxfield wrote:Yes but fuzzy we're talking to different banks here.
i understand your point max and your right. i hadnt thought my reply through properly :o:
me and my 4 pot tracked mind :D
maxfield
Not always a bad thing :wink:
e30_Turbo
Boost Junkie
Post Tue Nov 27, 2007 11:02 pm
http://streettuners.vidiac.com/video/4b ... c1f83c.htm
specs.
M70B50 engine
Getrag '850 only' 226 6spd gearbox
E30 M3 axles
Autronic SM4 engine management
Custom intake manifold with single throttle body
SST exhaust manifolds
Custom turbos
Double 3" exhaust
Custom IC
42mm Wastegates
Alu radiator, expansion tank
Twin fuel pumps
444cc injectors
6 cyl direct ignition (yes, the other half with single coil icon smile
Race fuel cell
How much money spent? :cry:
Gunni
Post Wed Nov 28, 2007 12:21 am
Not that much as Saku of Finland built that for his friend so labour is not a issue.
but trans is 3k euros what ever way you look at it
Gunni
fowler
Boost Junkie
Post Wed Nov 28, 2007 12:31 am
that looks the absolute nuts :cool:
EX A-Tech Workshop bitch !!!
gone but not forgotten
Post Wed Nov 28, 2007 7:28 am
bet that goes well..
buster
Post Wed Nov 28, 2007 9:40 am
Nice !
I've just has an idea :D
Is the m70 the normal 750 motor ? If so ,buy one as they are cheap as chips.Then fit turbo and gubbins as you would an m20 2.5 but times 2 = powerfull engine winkeye
oldroydsr4
Post Wed Nov 28, 2007 6:18 pm
Get
Maximium boost By Corky Bell and read it.
It will benefit you hugely and talk you through selecting the correct turbo etc
treeseries
Post Thu Nov 29, 2007 6:02 pm
who owns this car? where can i find more info on it?
e30_Turbo
Boost Junkie
Post Thu Nov 29, 2007 8:08 pm
Gunni wrote:Not that much as Saku of Finland built that for his friend so labour is not a issue.
