ive just pulled apart the ecu from the case . and how do you get the boreds apart to get to the chip.
dont want to just go in ham fisted .
cheers!
help with chip
psychochild187
Davenotouring
You have to bend the little metal tags and undo the screws, just be light-fingered.
BMW 328i Cab - Daily Slag
psychochild187
ive done that
it wats after that
it wats after that
Davenotouring
I'm a bit confused...
You should be able to pull the lid of to reveal the circuit board?
The chip you want is under the plastic cover, and carefully remove it by levering it either side until it becomes free.
JAMZ
Phyco...just curious to what chip your using m8 and to what car as im thinking of doing it myself soon..
cheers
cheers
psychochild187
ive got the old school one
its a 073 but i can see the chip but its in the middle of a 2 layers of cuircut boards , like a sandwich.
but it looks well in there!
psychochild187
its also got a little square thig with a hole in it that has a triangle shaped hole in the middle that turns
.( god knows wat this does but i want to fiddle with it!)
psychochild187
done it .
i found the way they put it together. wasnt easy but got there , after that its a doddle!
Ant
- Retired Team Member
the square thing is the fuel quality switch dude, mess with @ your peril
the 073 ECU is a PITA full stop, glad you cracked the puzzle though dude
Email FTW
psychochild187
i did mess with it !
i put it back
but is it really sensitive!
wen u mean qulity as in ocktane number !
i put it back
