poly bushes
salami
Post Mon Nov 12, 2007 1:41 pm
is it worth replacing all of my bushes with poly ones or do just certain ones need changing to make it handle better?
87 325i
oldroydsr4
Post Mon Nov 12, 2007 7:03 pm
Personally i would replace them all, however it is a bitch of a job and you will only see a big difference if the ones you replaced are fu*ked(which they will probably will be)
ed325i
Post Mon Nov 12, 2007 7:17 pm
I would replace them all.
You can get them from here >> http://www.e30zone.net/modules.php?name ... ic&t=15274
Gortour
Post Mon Nov 12, 2007 7:23 pm
I understand that you're better getting new BMW ones than the Poly bushes, unless you're going to put it on a racetrack.
DRIFTBOY
Post Mon Nov 12, 2007 7:30 pm
A lot of people say that.
I have poly bushed everything on mine except the engine mounts and I don't find it harsh at all.
Maybe I'm just tolerant of it after the lowered Minis and Mk2 Escorts etc.! :?
salami
spot on
cheers
87 325i
12345kevin
Post Mon Nov 12, 2007 7:34 pm
DRIFTBOY wrote:A lot of people say that.
Snap, and i'm using stiff "spax" shocks and springs. May be a different story when the H & R Anti Roll bars go on though :D
salami
its just going to be a trackday car so as long as its as stiff as poss winkeye
i will be happy :D
87 325i
Theo
Post Mon Nov 12, 2007 7:36 pm
Gortour wrote:I understand that you're better getting new BMW ones than the Poly bushes, unless you're going to put it on a racetrack.
Err, this is in the motorsport/trackday forum is it not?
I definitely rate the poly bushes, i've got poly subframe, diff, gearbox and engine mounts on mine and they are great. I did use solid rubber eccentric wishbone bushes after hearing a multitude of horror stories regarding the powerflex version of these.
DRIFTBOY
Post Mon Nov 12, 2007 7:38 pm
12345kevin wrote: May be a different story when the H & R Anti Roll bars go on though :D
I doubt it mate, mine still rides like a limousine compared to a Mk2 Escort! :)
I'm using H&R springs though and I reeeeaaalllly rate them highly, sooo much better than the two sets I had on before those!
Next time we meet I'm more than happy to take you round the block in it so you can compare it to yours if you wish?
1an
Post Mon Nov 12, 2007 8:08 pm
cant rate them enough, even if my set-up seams to be more crashy them my dads (12345kevin) bearing in mind he has a full spax kit and i have spax springs OE bilstein shocks,
and your quite welcome to drive my car if you can get the clutch down etc as i have a fixed seat in mine.
Gortour
Post Mon Nov 12, 2007 8:21 pm
Sorry, missed that small technicality... :o:
JimmyC
Post Mon Nov 12, 2007 8:23 pm
Polybush all round, BMW M3 on the control arms
Have seen 4 powerflex control arm bush failures, and been told about numerous others, not sure about the other suppliers of polybushes as never seen their CA bushes
northloop
Post Tue Nov 13, 2007 9:23 pm
I have a full set of poly bushes on the car.
However
A friend of mine who works for Jaguar in the suspension / set up area wrote a large article on this a while back. Basically he feels that new rubber is better than poly. I did post it in this section some time back. It might be worth a read if for no reason than to generate debate :wink:
DaveD
E30Zone Wiki Specialist
Post Wed Nov 14, 2007 12:20 am
what about the treehouse setup instead of the m3 eccentric
salami
Post Wed Nov 14, 2007 10:58 am
thanks northloop,i think i may just try replacing with rubber as it hasnt seen new rubber bushes,and then see what the difference is over what is on now
m3 control arm bushes er on the control arms... and what others should i do?
and what does the eccentric thing mean? :mad:
87 325i
DaveD
Post Wed Nov 14, 2007 11:30 am
salami wrote:thanks northloop,i think i may just try replacing with rubber as it hasnt seen new rubber bushes,and then see what the difference is over what is on now
alters the steering geometry..best mod you can do..check the arb link arm bushes...they can be replaced with poly bushes from superflex
