dips and glens 750 converstion questions
treeseries
Thu Nov 08, 2007 7:47 pm
does anybody know, obviously some1 does what gearbox they used to do the 5litre converstion it says manual box but i thought they came with auto boxs, i read the whole thread and cant find what box it was im gonna do this swap myself and was interested.
Thu Nov 08, 2007 7:49 pm
think they are 6 speed manuals from the likes of 850csi. A very expensive bit of kit, i mean like £1K-£2K for a box
e21Jason
Thu Nov 08, 2007 8:07 pm
Hi
It was a rare and V expensive 850csi box
Jason
treeseries
Thu Nov 08, 2007 8:22 pm
does any1 know of any other boxs that mite fit etc
glenn
Engine Transplant Services
Thu Nov 08, 2007 9:01 pm
:wave: :wave: :wave:
we used a 6 speed box out of a 850csi
dips346
London Meets Main Man
Thu Nov 08, 2007 9:06 pm
as said above 6 speed from a 650csi ,not cheap and not easy to come by .
i dont think anythink else works ,you could always buy my car :D
Yaninnya
Thu Nov 08, 2007 9:09 pm
treeseries wrote:any other boxs that mite fit etc
No, only S6S 560G gearbox from 850i (manual - rare) and 850CSi (even more rare).
Jan
treeseries
Thu Nov 08, 2007 10:56 pm
how much is your car likely to set me back dips?
crazymonk
Sat Nov 10, 2007 8:16 pm
I don't know if the 6 speed box from an E36 on M3 Evo would fit? they are geared to take a similar power to the V12, but I don't know if they fit the V12 engine?
Sat Nov 10, 2007 9:00 pm
S50 box is never going to fit, it would probably be cheaper to have a piece of auto box bell housing tigged onto an S50 box than find one from an 850
treeseries
Sat Nov 10, 2007 9:30 pm
i dont suppose i could grab a list of parts off you could i? or glen if you wouldnt mind writing out the idiots guide to v12 swaps that would be a great help
glenn
Sat Nov 10, 2007 10:23 pm
treeseries wrote:i dont suppose i could grab a list of parts off you could i? or glen if you wouldnt mind writing out the idiots guide to v12 swaps that would be a great help
if i had to write out a guide, then it would be like re-writing the original thread.
it might be easier if you made a start on your conversion and give me a shout if you get stuck on something and i'll do my best to help.
dips346
Sat Nov 10, 2007 11:09 pm
as glenn said ,but dont take this conversion likly as you will need a fair but of money to do it right plus the main thing of a gearbox , 99% sure you wont get a auto box in they as the engine will not sit in the right place at all
benjy
Sat Nov 10, 2007 11:17 pm
Ive got the removable bellhousing from a 750 auto box, if its of any use to you......
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
treeseries
Sun Nov 11, 2007 12:50 pm
thanks every1 for your comments i know its gonna be a challenge i think ive found the box though so im ok there. its not a project i plan to rush as the car its goin in is an on goin project with me so dont expect to see it any time soon. but i'll do my best and keep in touch.
jkarran
Mon Nov 12, 2007 4:54 pm
Have a look on www.locostbuilders.co.uk and search for 'bellhousing', 'gearbox adaptor' and the like, loads of simple innovative ideas on there along with tips on getting alignment right. First thing I'd consider after not finding an E31 box is welding the bolt ring (cut down) from a 750 autobox onto a cut down manual from something with a similar power output (M3, M5, Supra, T5 etc). Either that or make an adaptor plate.
What flywheel and clutch have others used? Can you still buy a new flywheel and ring-gear?
jk
E30 320i Rally Turd - Usually broken
E24 635Csi - Rotting in peace for now
E34 540i - Daily driver
Blown R1 Striker - In progress
**BANNED**
Mon Nov 12, 2007 5:35 pm
There was a bit in the Alfa V6 thread about making a bellhousing.Not something for the fainthearted,mind,a V12 into an E30 is much like that....
Youth is wasted on the young.
chu346
Wed Nov 14, 2007 9:08 pm
Toby_Unna
Boost Junkie
Thu Nov 15, 2007 1:49 pm
some useful info there Chu :thumb:
lambo replicas though :banghead:
jkarran
Thu Nov 15, 2007 3:18 pm
Pity none of those make clear how they dealt with the clutch, the best of the fake lambo motors still has the flexplate fitted in all the pics. Custom flywheel and clutch would cost more than the motor, wonder if any other stock flywheel will fit :?
jk
