Some kind of puller or some thing ?
I have drilled and battered to death two dowels so far but it took ages !
The first thing i tried was using a jig saw with a metal cutting blade and it hardly scratched it ! After one minuets sawing the blade was worn out,see the picy below.ant wrote:have you tried cutting through them Andy ? junior hack or coping saw should get in there to do the job
Erm,i'm a bit scared of using heat on them as the TB's are made from Aly.TOURINGDADDY wrote:
Have u got oxy acettlin or a blow torch.... heat up around the dowel (not the dowel) till glowin then get a firm grip with some moles and then u got ur self a weeeeeeee bit
I've tried it mate,it just bends the exposed end.I tried to hammer it with a screw driver sort of inbetween the dowel and the hole in which it sits but the dowel is well hard.If i had tried to force it any more i think the TB would have broke by the hole if that make any sence to you.I'm a bit shit at describing stuf some times.Karan wrote:can u not hit it with a chisel and bend it inwards...?
