rearwheel camber/castor/toe adjustment
dred
Post Sat May 21, 2005 7:56 am
I have just been to get my tracking done after getting my rear
bushes and springs kit .
bad news my rear wheels are out in every way,toe,camber thrust angle,
what can i do to fix this,eccentric bushes diffrernt top plates some
one must have come acrossthis promlem
mrLEE30
Post Sat May 21, 2005 8:33 am
I remember this topic generated a heated debate about the effect on camber when changing shocks etc, you new zoners wont remeber, but us old school will!!! :cool: lets bring it back up as i enjoyed it!!!!!
Dred mate i cant help you but i am sure someone will answer. I am assuming you changed all the bushes and that nothing has been bent or extreamly worn?
mrlee
mrLEE30
mrlee
astondg
Post Sat May 21, 2005 8:45 am
I have K-Mac adjustable trailing arm bushes that can adjust camber and toe. They were AUD$295 for the rear kit.
How much extra camber do you have? A little bit extra wouldn't be a big problem and will help handling. A lot extra and it will wear the inside of the rear tyres quickly.
Aston
BMW E30 323i with some stuff
1:05.17 @ Queensland Raceway Sprint track
1:10.09 @ Queensland Raceway Clubman track
1:21.67 @ Morgan Park Raceway
TOURINGDADDY
Post Sat May 21, 2005 8:56 am
I cant rember where u can get these from but there is available some ajustable top mounts 4 the e30 and as bloke above says about the camber some will help the handling but to much will wear tyres out like that. A couple of years ago i had a granada cossie and when i slammed it -120mm my rear camber was 28 degrese and usde to wear tyres out on the inside edge in 8000 miles plat with rotation and remove an refittin in opp direction..... left it like ik it coz i could go round corners at some stupid speeds that u would'nt dream of doin..... 8O
Karan
Post Sat May 21, 2005 1:23 pm
u cant adjust the camber/toe unless u get eccentric bushes in the trailing arms, the bushes may be worn, but generally all e30s show dodgy rear readings, as long as each side is about the same it doesnt really matter...excessive lowering an cause lots of neg camber like on my car, but this helps handling neway, although i do get thru lots of rears :cry:
dred
Post Sun May 22, 2005 8:41 am
these are my readings for the rear left camber -1.06toe -1.31
right rear -1.47 toe-;0.16
total toe -1.47
thrust angle -0.38
Karan
Post Sun May 22, 2005 11:30 am
hmmmmmm mine are a lot closer to each other than that and mine is lowered 60mm...... it may have had a kerb knock and bent something in the rear...... its a VERY long job but may be worth changng the whole back axle..... 8O
