m50 engine mounts in e30 touring conversion
bruce62
Post Tue Sep 18, 2007 4:35 pm
i'm currently fitting a m50 into my 325 touring. in other conversions i've seen the engine mounts are square but i'm only able to get round ones. does anyone know which to use (does it really matter?) and if so what the part number is?
ste
Post Wed Sep 19, 2007 9:45 am
I've never seen square engine mounts. Use the E28 M5 rubber mounts with the standard E36 metal mount arms and it'll all line up perfectly.
Post Wed Sep 19, 2007 6:39 pm
You mean these?
E28 M535i
Part No - 118 111 327 93
http://www.realoem.com/bmw/showparts.do ... g=10&hl=19
bruce62
Post Wed Sep 19, 2007 6:54 pm
many thanks will get them ordered, might have it in and running by end of the weekend if i'm lucky winkey
Post Wed Sep 19, 2007 7:29 pm
You will be lucky to get those mounts for the weekend!!
old_skool
Post Wed Sep 19, 2007 7:35 pm
Don't you just want one of those though? The other side is a round mount and has a different part number :?
BMW UK do keep them. If you order it with a dealer tomorrow they should have them for friday.
8)
Post Wed Sep 19, 2007 7:40 pm
I used two of those mounts Dameon, they just look more solid than the round type. Work well on mine anyway
old_skool
Post Wed Sep 19, 2007 7:51 pm
DanThe wrote:I used two of those mounts Dameon, they just look more solid than the round type. Work well on mine anyway
Really?
Never heard of that before. You are right, they do look more substantial than the round plain rubber N/S mounts. Not sure without checking whether or not the dimensions are the same or not.
If it works then it works! I know all the S50 conversions are wearing the two different mounts (that I know of)
jaistanley
Post Wed Sep 19, 2007 7:53 pm
Has anyone used the round type? I ordered the E28 mounts for my S50 conversion and have one of each.
Did I get the wrong (round) type? :cry:
Jai
Post Wed Sep 19, 2007 8:59 pm
Im pretty certain they are the same height as the E34 round rubber mounts. Will check it out tomorow
ian332isport
Post Thu Sep 20, 2007 9:33 am
jaistanley wrote:Has anyone used the round type? I ordered the E28 mounts for my S50 conversion and have one of each.
Jai
Jai,
No, you have the correct ones. The green hex shaped one goes on the drivers side, and the round one goes on the passengers side. I believe the difference in design is because one is primarily operating in compression, and the other in extension.
Ian.
ste
Post Thu Sep 20, 2007 2:47 pm
Absolutely how I understand it. Under load the engine twists along the front/rear axis exerting twist on the mounts, one under compression the other under tension. The mounts are designed to do completely different things.
Post Thu Sep 20, 2007 6:14 pm
ste wrote:The mounts are designed to do completely different things.
So what happens under engine braking conditions? Surely they would swap roles
Post Thu Sep 20, 2007 6:21 pm
not really as there isnt as much of a force being applied by deceleration..
bruce62
Post Thu Sep 27, 2007 10:02 pm
hi again i got the mounts on friday, got the engine and box fitted at weekend been building the exhaust system and finally got it running yesterday.
