upsidown manifold?????????
bmwcoupe
Post Sat Aug 18, 2007 3:05 pm
hay guys can some 1 help me it does sound stupid but also makes some sence can u turn the m20 manifold upside down and mak a flangge hehe {flange} and bolt up a turbo 2 it instead of making up a whole mannifold???
Kos
Post Sat Aug 18, 2007 3:08 pm
its been many times but you need to re drill the mounting holes for the studs and even then i belive there are still "overlap" issues with the ports lining up
www.pukardesigns.com
IG Pukar.Designs
gareth
Post Sat Aug 18, 2007 3:13 pm
i thought the 2 piece 320 manifold worked?
not that i've looked on a M20 but i though this might be handy for a M30 turbo.
blingsta
Boost Junkie
Post Sat Aug 18, 2007 3:46 pm
mines been done! no overlapping issues here, i bought it from a zoner who had it re-ported and re-drilled the mounting holes as Kos said... :D .. works a treat!
isTURBO
Post Sat Aug 18, 2007 4:15 pm
bmwcoupe wrote:hay guys can some 1 help me it does sound stupid but also makes some sence can u turn the m20 manifold upside down and mak a flangge hehe {flange} and bolt up a turbo 2 it instead of making up a whole mannifold???
From what ive been told in South Africa Lots of 327 turbo conversions are employing the same technique and works well. :twisted:
Kos
Post Sun Aug 19, 2007 3:03 pm
it does work well when done right
IG Pukar.Designs
Turbo-Brown
Boost Junkie
Post Sun Aug 19, 2007 3:52 pm
Has anyone tried leaving the manifold in it's standard position and then plumbing the gasses back up to a turbo? Kinda like those John Volk adaptors you can buy for the US exhaust manifolds?
isTURBO
Post Sun Aug 19, 2007 9:26 pm
Turbo-Brown wrote:Has anyone tried leaving the manifold in it's standard position and then plumbing the gasses back up to a turbo? Kinda like those John Volk adaptors you can buy for the US exhaust manifolds?
Thats an interesting point. :wink:
Wouldnt the distance from the manifold to the turbo affect the performance in some way though?
Still new at this so please forgive me if Im wrong.
Colonel Sanders
Le Surrender Monkey.
Location: guernsey.... i mean france munching on garlic and drinking wine with my children.
Post Sun Aug 19, 2007 9:42 pm
it shouldnt do really if you look at some of the equal length manifolds out there
isTURBO
Post Mon Aug 20, 2007 12:12 am
Just been talking to a Mechanic and he said that having the manifold a distance from the turbo unit would cause lag as the gas would have a longer distance to travel. Apparentlt it should be located as near to the turbo as possible.
Turbo-Brown
Boost Junkie
Post Mon Aug 20, 2007 1:44 pm
It's not so much the distance the gas needs to travel per-se, it's more the heat it loses on it's way to the turbo.
Turbo response times are massively effected by the temperature of the exhaust gas (another reason I can't see the point in rear mounted tubbys)
I think for a low cost and easy conversion the idea might have some merrit.
Certainly the adaptors from the states can flow for quite a lot of power so there's no reason something to fit a UK mani wouldn't :D
Stifla
Post Mon Aug 20, 2007 10:56 pm
Im having trouble picturing this but by turning the manifold upside down, im assuming you guys do this so as to mount the turbo at the front of the engine for clearance etc?
gareth
Post Mon Aug 20, 2007 11:03 pm
yep :)
turbocrazy
Post Wed Aug 29, 2007 8:39 pm
can u use a spanner also we don a drawring and i fort it was a good idea any help :?:
BadDave
Post Wed Aug 29, 2007 9:07 pm
You could also use the manifold from a 324tds flipped upside down
Has the added bonus of having a T3 flange already on it and a take off for an external wastegate
Looks something like this
Dave
turbocrazy
Post Wed Aug 29, 2007 9:16 pm
how much would a 324tds cost me
BadDave
Post Wed Aug 29, 2007 9:22 pm
Dips sold one on ebay a few months back and it went for about £130 ish IIRC
Mine came with the turbo(turbo for sale) with the work done to make it work upside down.
Got it for a little more than Dips's one
Don't see them on the market that often.
I haven't anyways
maybe I was looking in all the wrong places
Dave
turbocrazy
Post Wed Aug 29, 2007 9:29 pm
i was thinking of making it myslef got any tips
BadDave
Post Wed Aug 29, 2007 9:32 pm
Toby got manifold flanges for £10ea and the turbo flange was £20 IIRC
Try and get a back copy of PPC
Toby had a write up about turboing his M30 powered chariot
if you can't or havent welded before, Get someone competant to do it for you
turbocrazy
Post Wed Aug 29, 2007 9:35 pm
i can do it myself
i was tinking a t4 turbo
BadDave
Post Wed Aug 29, 2007 9:42 pm
Got 1 of those here
NOT for sale though
turbocrazy
Post Wed Aug 29, 2007 9:50 pm
is there a lag problem
i read it in a fast car magzine
isTURBO
Post Wed Aug 29, 2007 10:02 pm
turbocrazy wrote:i can do it myself
Yeah I have a T34 myself and wanting to flip my manifold too.
Much cheaper I believe.
I know Blingsta has a flipped manifold on his turbo setup.
Good Luck :D
BadDave
Post Wed Aug 29, 2007 10:13 pm
turbocrazy wrote:is there a lag problem
From what i've read on here
A large hotside is needed on the good old M20
Can't comment on the lag issue, as it's not fitted YET
isTURBO
Post Wed Aug 29, 2007 10:19 pm
Hi Mate
Not to butt in but Ant does these conversions all day and it would be worth your while to contact him.
Hes also a very helpfull guy.
Cheers 8)
BadDave
Post Wed Aug 29, 2007 10:22 pm
Hi Mate
Cheers 8)
The more people who contribute all adds up to a larger database of info for future use to all on the zone
isTURBO
Post Thu Aug 30, 2007 11:08 am
Thanks Bad Dave
Cheers :D
