K&N essay
greentouring
Sat Aug 04, 2007 8:41 am
Today I managed to find a couple of hours for E30 stuff!
The good: At last the filter is fitted. I took 'ye old Touring' on an 82 mile round trip and she ran very smoothly. I also noticed the temperature sat on quarter or just below for 95% of the journey, even when I opened her up!
The bad, and the ugly!:
1) Fitting was a bugger, although it was done within an hour. There were four bolts that connect the airflow meter to the air box, and these have to be removed with two â€Ëaspecial' nuts provided. It wouldn't happen. I found that by leaving the existing nuts the gasket and adapter fitted perfectly (more or less). However, I want to do it right, so if anyone can suggest how they removed those darn bolts, please do (I can provide a copy of the instructions if needs be).
2) The mounting bracket that connects to the second hole where the original air box originally fitted caused most problems. The bracket supplied has a curve for some reason, and didn't fit flush to the original position of the old air box. I managed to tighten some bolts to keep her on, as a temporary measure. Also, the whole airflow meter was slanting downwards quite a way, which surely can't be correct. A mate suggested I fashion an extension to fix to the bracket to hold the AFM higher and level which I did. It works, but I want it looking neater, so any ideas again would be useful. Photos of the install even better.
3) Finally, there's a pipe supplied and it looks like I have to also cut holes in the grill according to instructions. I found that positioning the original air intake pipe is neater with a better fit, so bent it into a way in which it will feed the filter.
4) I can't hear any noticeable noise change. When I rev it up hard, then got to rev her up again, there is a 'gulping of air noise', but not much else???
Please see photo:
suggestions for that bracket problem (I think I have the wrong one, but I ordered this 3 months ago, it sat in the UK, as they wouldn't send to France, and I eventually got it this week! I noticed on top of the instructions it says 318i and mine's a 316i. It all works, it's just the bracket and I'm sure the 318i doesn't differ in the mounting bracket for the AFM, thus it's maybe the same kit for both cars. I'm sure you guys understand, I like everything looking neat and spot-on and don't like bodge jobs...lol
ed325i
Sat Aug 04, 2007 9:19 am
Are you going to build a heat sheld ?
greentouring
Sat Aug 04, 2007 6:49 pm
Yeah, I will probably buy one, maybe one of those from ebay. If anyone has any comments on improving this install, please feel free. :)
ed325i
Sat Aug 04, 2007 8:20 pm
It looks fine just make sure its getting lots of cold air from the front of the car.
Sat Aug 04, 2007 10:02 pm
greentouring wrote: If anyone has any comments on improving this install, please feel free. :)
Remove cone filter. Refit OEM filter box and filter. Sell cone filter to Saxo/Corsa owner via ebay.
grantfk10
Sun Aug 05, 2007 1:03 pm
:rofl:
greentouring
Sun Aug 05, 2007 1:51 pm
:) I knew that was just around the corner...lol You're probably right too,Brian, however, the trouble I went through to actually get this to France means it WILL be staying right where it is....for now at least! :wink:
Any constructive comments, please..... winkeye. It does actually keep the engine a lot cooler.
Sun Aug 05, 2007 2:57 pm
greentouring wrote: It does actually keep the engine a lot cooler.
In a car in full working order, the engine temperature is controlled entirely by the water thermostat.
The only way the air filter could be responsible for the engine making less heat is if it restricted the airflow enough to enrich the mixture!
greentouring
Sun Aug 05, 2007 9:20 pm
I see :o: Oh well, I live and learn....thanks. I better learn something about mechanics! :wink:
316eyes
Sun Aug 05, 2007 11:38 pm
You don't need to learn about mechanics.
Just do as Brian tells you. :bow:
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
