the horn itself is ok (tested) and the connector doesn't seem at all corroded. the horn button is fine and the slip ring on the column is good. all fuses are ok too.
that leaves a relay possibly? i wnr to look in the haynes joke book and the index donsn't even have "horn" in it! nothing!
is there a horn relay and if so, which on is it? cheers
