Hey guys the M20 out of my tech 2 is in need of an over haul, so just enquiring how much work it would be to Lengthen the stroke to 2.7 (nice short bullet points would be ACE)
Also many Pros/cons?
M20 lengthed to 2.7 - How much work?
George_Of_The_Jungle
dazleeds
- old skool raver
525e block
and a 325i head with some machine work to the head
i may have all the bits for sale very soon
just decideing whether or not to build it at the moment
have a look in engine swaps section this is a very well documented transplant now
www.oldskoolfantasy.co.uk
- Homo Hair
Does no one understand how to you use the search function anymore?!
maxfield
A good search will bring up 100s of 2.7/2.8 threads.Jhonno wrote:Does no one understand how to you use the search function anymore?!
march109
Alot of new members OP included probably don't know its there and its not the easiet thing in the world to use, especially if you've not been around and don't know what terms you are looking for.Jhonno wrote:Does no one understand how to you use the search function anymore?!
For example if you search for 2.7 as you suggested it throws up No topics or posts met your search criteria, probably because the search term isn't a string.
Now Daz has told him what parts are needed at least OP has more terms to use in the search function and help narrow his list of results.
ed325i
Why not build a 2.8 less work than a 2.7
oze30
I have all the parts bar the head for a 2.7 Both Hi and lo comp engines. Not that difficult or hard depending on which one you want.
PM fpr details.
O/T
Daz, LPG???
PM fpr details.
O/T
Daz, LPG???
