MattW
Post
Mon May 02, 2005 12:02 am
Hi all
I know they need to be pointing towards your ear, but where do you mount them? Pics would be good
Can you mount them with the footwell speaker, but pointing up towards the driver?
thanks for any info
matt
Adammcf
Post
Mon May 02, 2005 12:20 am
My car came with them in the little triangle plastic backing of the door mirrors. They do the job and you can definitely hear them ok.
amit325i
Post
Mon May 02, 2005 12:58 am
i mounted mine on my door cars, easiest, but there will be holes on removal.
johnono
Post
Mon May 02, 2005 1:06 am
i got components, so the tweets go on the wing mirror triangles, and look almost the same as oemԚ´s
happy with the sound difference also
placey
Post
Tue May 03, 2005 12:35 pm
matt
every set of speakers and set of listening ears will have a different ideal mounting position for the tweets. idealy you'll have them loose on a longish wire with some tape/blu-tack handy so you can try them in various locations and listen to what works best.
mine are on the door cards - but that what sounded best to me!
paul
i saw a doctor and she gave me some pills....
MattW
Post
Tue May 03, 2005 12:47 pm
cheers lads
getting my ideas ready for when the e30 arrives!
hoshy
- E30 Zone Wiki Guru
Post
Tue May 03, 2005 12:52 pm
I've got mine screwed to the dash in the far corners, around the tax disk sort of area on each side. seem to work well enough there but having listened to placey's over the weekend I'd be following his advice
You may wanna check out the guide he wrote in the articles section of the site.
MattW
Post
Tue May 03, 2005 8:08 pm
cheers hoshy, i didn't see the guide before posting
ta
matt
AlpineCab
Post
Sat May 14, 2005 8:03 pm
get the tweeter pods that fit into the door where the wing mirror is. Then prise out the oem tweeters and wedge yours in with blue tack. the wiring is all there ready to go...
hoshy
Post
Sun May 15, 2005 11:16 am
AlpineCab wrote:get the tweeter pods that fit into the door where the wing mirror is. Then prise out the oem tweeters and wedge yours in with blue tack. the wiring is all there ready to go...
are these still available from the dealers?
TOURINGDADDY
Post
Sun May 15, 2005 3:52 pm
coz you cant get them close to your head put them close to the front screen and use that to amplfy the sound. trust it will.
JazzMan
Post
Sun May 15, 2005 5:31 pm
Get an extra long bit of speaker wire and some bluetack. Try the tweeter in different positions.
If they are up high you may need to attenuate them with -XXdb setting on the crossover or they can sound harsh.
Use a CD such Christian Aguilera - Stripped. Shes got a voice thats ideal for positioning tweeters as you can tell if things are getting too harsh very quickly!
It's all about trying were they sound/work best. Typical places are in the kickwells, A pillers or mirror triangles.
Kickwells are a bit tricky in BMW's because of the big center consoles (maybe not so much in the E30 I think). I've quite successfully got a 3 way system running in the kicks in my E46 (mid in stock locaiton).
chu346
JazzMan
Post
Sun May 15, 2005 5:47 pm
I was expecting that, still for testing its a good disk ;)
AlpineCab
Post
Tue May 17, 2005 5:47 pm
Yes, they are still available; not too expensive for a completely oem look
hoshy
Post
Tue May 17, 2005 11:30 pm
I may have to uinvest ni that case. shame I already put screwholes on the dash
LOOPYLEE1965
Post
Tue May 17, 2005 11:54 pm
ive got mine mounted up on the roof lining i ran the wires up the rubbers on the a posts and then attached them where the trim ends just before the roof lining sound nice and crisp as they are pointing down towards your ears notgot any picsbut if you want to know what i mean can try and post some 2moz
