Cotty
- Hartge Crew
Post
Sat Jun 02, 2007 5:04 pm
I started putting on the stripes and stickers for Le Mans today. C0cked up one stripe which I might redo if I have enough left over. People who have seen my car know that I will never fit the door numbers on due to my Hartge stripes so I whacked one on the bonnet, Now I don't now where to put the second one.
What do you think of the rear window like this
Progress so far
Still need to do the tailgate and roof which is going to be a PITA
tezk
Post
Sat Jun 02, 2007 5:16 pm
I wasn't too sure when I saw the "from above and in front" shot, but that last one looks pretty good
d6dph
Post
Sat Jun 02, 2007 5:28 pm
Looks good Paul, Not too tricky is it.
Cotty
- Hartge Crew
Post
Sat Jun 02, 2007 5:34 pm
d6dph wrote:Looks good Paul, Not too tricky is it.
Im finding it a little tricky. I suppose you need do do a few to get good. The stripe next to the number on the bonnet is the first one I did and its a bit crap where the crease is in the bonnet so my redo that. Shields and number no probs.
I tried the soapy water method but had problems with trapped water and not being able to get it out
d6dph
Post
Sat Jun 02, 2007 5:47 pm
Pop the water pockets with a pin, squeeze the water from the pockets.
Bit like popping a spot!
Jon_Bmw
- Dangerous when thinking
Post
Sat Jun 02, 2007 6:13 pm
Nice Paul, i'm not looking forward to covering all of mine either. Its going to take ages, especially the roof. I would put your other number on the drivers side on the roof at the back corner. So its diagonally opposite the one on the bonnet. I know you won't see a lot of it, but anywhere else won't look quite symetrical in my opinion.
1an
Post
Sat Jun 02, 2007 6:50 pm
on the bonnet we found the best method was to cut the stripe on the bonnet to follow the curve of the raised bit instead of trying to get it to take to the crease if that makes sense.
Cotty
- Hartge Crew
Post
Sat Jun 02, 2007 7:24 pm
1an wrote:on the bonnet we found the best method was to cut the stripe on the bonnet to follow the curve of the raised bit instead of trying to get it to take to the crease if that makes sense.
Yes that does make sense. I had lots of material over after doing the roof so ripped the crap stripe off the bonnet. But i used to much water or too much saop and the bottom edge wont stick I have taped it down and hope it dries out overnight.
Now I have redon one of the bonnet stripes it makes the other look bad so I might redo that one as well
1an
Post
Sat Jun 02, 2007 7:28 pm
use a credit card or somin to remove the water form underneath. that will help it to dry easier.
Cotty
- Hartge Crew
Post
Sat Jun 02, 2007 7:33 pm
I used a credit card but it must be too wet, will see what its like in the morning
munky30
- 100% Pure Council
Post
Sat Jun 02, 2007 7:42 pm
it will stick eventually.
You can speed up the process by heating it slightly to dry out the water.
Pockets of water or air can just be popped as d6dph says.
Looks good. I'd put the other number on the window as you've shown.
duke wrote:
I could throw a spastic round a corner with better precision
Cotty
- Hartge Crew
Post
Sat Jun 02, 2007 7:59 pm
Jon_Bmw wrote:Nice Paul, i'm not looking forward to covering all of mine either. Its going to take ages, especially the roof.
I used lots of water and a couple of drops of fairy liquid in a spray gun that way you can put the stripes on and slide them around until you get them right then use a credit card to push the water out. I laid the roof stripes in one go then cut them where the sunroof edges are.
Just out of interest my stripes have a gap of one fag packet between them. Was all I had to hand, taped one fag packet each end of the roof then lined them up by eye. Ok its not great but they are only on for a month.
It cost me £40 to have my Hartge stripes put on, money well spent in my eyes as they are spot on and not coming off
Kedge
Post
Sun Jun 03, 2007 10:38 am
Looking good mate, dreading doing mine!
Cotty
- Hartge Crew
Post
Sun Jun 03, 2007 5:51 pm
Finished
. Ok so its a bit rough round the edges and there are some bubbles but the stickers are only going to be on for about a month
tylerma
Cotty
- Hartge Crew
Post
Sun Jun 03, 2007 6:05 pm
Looks a bit monochrome. If I go next year im thinking of doing martini or Gulf colours
Ziggy
Post
Sun Jun 03, 2007 9:34 pm
Jon_Bmw
Post
Sun Jun 03, 2007 9:35 pm
There had to be one didn't there
Cotty
- Hartge Crew
Post
Sun Jun 03, 2007 9:37 pm
Im liking the offset stripes no one said how we were supposed to use them. Mine are one fag packet wide, Guys are as they came.
d6dph
Post
Sun Jun 03, 2007 9:46 pm
That looks the nuts Jon! A little bit chav to go with the wheels
Ziggy
Post
Sun Jun 03, 2007 9:54 pm
A f***ing
lot chav if you ask me!
The stripes clearly look better like that - it's not just me trying to be different/difficult... honest.
I've got enough left over to either do another set t'other side, or do my Caddy too!
Jon_Bmw
Post
Sun Jun 03, 2007 10:02 pm
It looks good mate, I can't put mine on till thursday as I have an interview then. I dont think it is a good look
Work is stacking up on mine, needs a new shock and change the fuel pump and put the stripes on.
1an
Post
Mon Jun 04, 2007 9:30 am
ziggy, guy wont be happy. this was discussed by a few people at the white rabbit racing meet the other week, and the conclusion was everybody should have them down the middle.
Dan318-is
Post
Mon Jun 04, 2007 9:35 am
1an wrote:ziggy, guy wont be happy. this was discussed by a few people at the white rabbit racing meet the other week, and the conclusion was everybody should have them down the middle.
Rubbish! I swear someone at the clapham meet didn't have them central?
Its a lot easier doing it like the zigmeister has because if you do them centred you have to negotiate with the raised bonnet line of the e30 in the centre and it is very hard to squeeze the air out etc.
1an
Post
Mon Jun 04, 2007 9:38 am
nah jay wanted to on his e36 (one with z3 m-coupe wheels) but guy said everyone sohuld have them down the middle, as to look all the same etc.
personally i prefer them offset.
cliffybabe
- Powered by Nelly
Post
Mon Jun 04, 2007 9:56 am
looks good guys, Paul u've been talking to munky aint ya
Ziggy im liking it mate, maybe some chrome ones for mine
Ziggy
Post
Mon Jun 04, 2007 9:59 am
Guy (on WRR) wrote:Guys. I take my hat off to all of you ;D ;D. Cars look great and loving some of the individuality as well. Offset stripes look ace Ziggy!
Spent the afternoon stickering up MJG16's 911. His car looks ace. Post pic tomorrow.
Group photo Sunday night after the race will look awesome!
Cotty
- Hartge Crew
Post
Mon Jun 04, 2007 1:43 pm
Dan318-is wrote: Its a lot easier doing it like the zigmeister has because if you do them centred you have to negotiate with the raised bonnet line of the e30 in the centre and it is very hard to squeeze the air out etc.
and he didn't have to cut round the badge and washers
ric325i
Post
Mon Jun 04, 2007 2:53 pm
cotty180 thats nice work
i will admit i am not a fan of the vipor stripes but they dont look bad actually but i would have put the number on the bonnet on the left (other) side of the stripes and much closer to the lights.
IMO
it just looks a bit floaty lost up where it is.
best bit are your stripes down the side!!!!!!!!!! i have always loved them and remember seeing them on your e30 ages ago and thinking
Cotty
- Hartge Crew
Post
Mon Jun 04, 2007 7:28 pm
ric325i cheers for the comments
Like I say they dont bear close inspection, first attempt and all.
My stripe count is now 12
and 6 stickers
miniblob
Post
Wed Jun 06, 2007 7:11 pm
Looking good guys!!!!!!
Picked my stickers up and finally met Guy last night!!!!
Gonna have to try and put them on the car on sunday/monday/tuesday!!!!!
Quite liking the offset stripes - might have to copy that - although i do have another idea!!!!!!!
zaust
- Zone day release
Post
Wed Jun 06, 2007 7:35 pm
Lookin good fella's.. Rember loads of washing up liquid and water then you can move the stripes and get them right...
M30 Tech 1 Touring on gas.
Kedge
Post
Wed Jun 06, 2007 7:37 pm
Am i right in thinking that you have to wash the car with washing up liquid to get any polish/wax off the car so they stick?
Ziggy
Post
Wed Jun 06, 2007 10:53 pm
Nope... potentially if you wanted them to stick forever, but I'm guessing you don't?! I just washed mine with my normal stuff. (& then waxed it straight afterwards!)
buster
Post
Thu Jun 07, 2007 12:07 pm
can i just ask guys,whats with the stripes ? Is it a temp thing for going to le mans ?
