"Deep dish" Miglia wheels on ebay
DrBen
These wheels are stated as being "deep dish" yet they are only 7x15? anyone know if the ET13 offset really will fit the E30? I am questioning this guy cos he doesn't seem to know much. Any zoners got these wheels?
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... &rd=1&rd=1
StuBeeDoo
oakey
He seems like a bit of a plonker. why would you need to do arch work to fit them to a 325i when he also says they fit "straight on" every other e30???
and they arent particualrly cheap and look like they badly need a refurb
charlE30
They look
according to my tire calculator with ET13 they'd stick out an extra 11mm over the standard ET24.
Charlie
Charlie
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
StuBeeDoo
Mmmmm. Works out at roughly £160. I'd say they are a tad overpriced for what they appear to be. Depends on exactly how rare they are in Aus.oakey wrote:He seems like a bit of a plonker. why would you need to do arch work to fit them to a 325i when he also says they fit "straight on" every other e30???and they arent particualrly cheap and look like they badly need a refurb
StuBeeDoo
oze30
hey charl, can you work out what 17x8 et20 would be compared to stock et 24??
charlE30
http://www.e30zone.net/modules.php?name ... link&cid=8oze30 wrote:hey charl, can you work out what 17x8 et20 would be compared to stock et 24??
5th link down mate has the calculator, you'll need the tire size as you can't adjust the width of the rim but it sort of does it with tyre width.
Charlie
BMW F31 335d xdrive
BMW F31 335d xdrive
StuBeeDoo
et is measured in millimetres. Therefore, an et20 wheel would stand off the hub 5mm more than an et25 one, providing the rims are the same width.oze30 wrote:hey charl, can you work out what 17x8 et20 would be compared to stock et 24??
Or an et35 wheel would be 10mm further into the wheel arch than an et25. Same proviso applies.
If you keep the same width wheel and change the et then the track will change.
If you change the width of wheel and want to keep the track width right you need to alter the et.
StuBeeDoo
So to answer your question, using 15x7 et 24 as the baseline.....essbee wrote:et is measured in millimetres. Therefore, an et20 wheel would stand off the hub 5mm more than an et25 one, providing the rims are the same width.oze30 wrote:hey charl, can you work out what 17x8 et20 would be compared to stock et 24??
Extra inch width will move the outside edge of the wheel 12.7mm further out from the hub face.
Reduction of et will increase that to 16.7mm.
Therefore the inside edge will be 12.7mm - 4mm = 8.7mm further in (ie towards the centre of the car).
Ideally 8" rims on an E30 should have roughly et11.
Wheel diameter has no bearing on the required et.
MJG
17x9 et8 z3m is what you want you pansies. Expect to need lots of arch work though, and 5 studs
liam012
has anyone managed to easily fit the et13 mim 1900's to the rear of their car?
MJG
My mate had them on his, no worries at all. They are only like 7.5 or 8j aren't they?
Just clean out the inside corner where the arch lip goes inwards, with a wire brush/rag/your fingers, then warm up the lip with a heat gun, and gently hammer the lip upwards and outwards. Before it seals up against the outer vertical face of the arch, just jam some waxoyl in there and then hammer it flush. Job's a goodun.
StuBeeDoo
boxclever1753
i have them too - they don't need arch mods....
Geoffsco
Any E30 rims are hard to find in Australia, even baskets are quite rare. Condition looks pretty ordinary, but I think the price is OK so long as they're not buckled.Mmmmm. Works out at roughly £160. I'd say they are a tad overpriced for what they appear to be. Depends on exactly how rare they are in Aus.
Big_M
I'll agree with Geoffsco. Anything ya have in abundance in the uk we don't get here in OZ in anything like the quantity. Makes me wish i'd packed up crate loads of spares before i moved over !!! E30 rims aren't readily available at a sensible price. So peeps get what they can. Me i'll be coming back to the mother land or sourcing some parts and getting the olds to bring/ship em out !!!
