JonnyBravo
Post
Thu Apr 28, 2005 9:59 am
Hello there
Got news yesterday that my head gasket is leaking oil
and that means the head will have to come off
So while the Head is off I was thinking about getting it ported and polished. Would it be worth porting and polishing the head? Is there any other mod I could do while the head is off?
Many Thanks People
Davenotouring
Post
Thu Apr 28, 2005 11:28 am
You could put a new cam in?
Say a Shrick cam, people will reply will particular ones I hope but it's an idea?
Cheers.
BMW 328i Cab - Daily Slag
- Homo Hair
Post
Thu Apr 28, 2005 11:30 am
i wouldnt bother with porting... unless your gonna fit a cam
Shrick 284/274 should do the trick
JonnyBravo
Post
Thu Apr 28, 2005 11:46 am
thanks for the replays
where would i get the "Shrick 284/274" cam from? and wat gain would i get from fittin the new cam?
Jonathan
Project_E30
Post
Thu Apr 28, 2005 1:09 pm
cam is going to set you back a few hundred quid.
Polish the exhaust ports. This helps prevent carbon build up. Leave the inlets as it needs the little turbulence.
JonnyBravo
Post
Thu Apr 28, 2005 1:29 pm
wat BHP would you get from new cams? seen a set for 340 alot of money to spend need to be gettin some BHP out of it
just got myself a new head there from a mate
he said its from a 525e but its the same head, is this right?
numbers on the head are "1 264 200" "2.7 ETA" if that helps
cheers
Jonathan
Widge
Post
Thu Apr 28, 2005 1:35 pm
I think you'll find that head is not the right one, sorry
Try reading this article it should shead some light on it.
http://www.totalbmwmag.com/HandsOn/TechMay01.PDF
As far as tuning goes if you go for a cam there is no point unless the rest of the engine is in good nick/running quite well, so you need to make sure the whole fuel injection sys and igition is running well. If you do go for a cam you'll need new rockers and shafts too, and it would be worthwhile getting a chip and BBTB to take advantage of it, no point opening the valves more if the inlet side of things is just going to restrict the air flow
You'll probably want some sort of upgraded air filter too.
- Homo Hair
Post
Thu Apr 28, 2005 1:49 pm
JonnyBravo wrote:wat BHP would you get from new cams? seen a set for 340 alot of money to spend need to be gettin some BHP out of it
cheers
Jonathan
nope - wrong head entirely!!
Cam n bit of headwork with chip is good for 20bhp n nice mid range n top end
JonnyBravo
Post
Thu Apr 28, 2005 2:12 pm
wait till i get hold of him lol good job i never paid for it
the head came off a 325i block, wonder how he had it goin then?
cheers for all the info people, all a big help
cheers
JonnyBravo
Post
Thu Apr 28, 2005 3:37 pm
Sorry about all the question
that head i have, i take it she would be the 2.7 alpina/hartge then?
Widge
Post
Thu Apr 28, 2005 3:42 pm
Nope it will be off a 525eta which is the M20 2.7 low compression engine which was produced for efficency because of the greenies in the '80's. Has he got the rest of the engine it came off?
JonnyBravo
Post
Thu Apr 28, 2005 3:47 pm
Widge wrote:Nope it will be off a 525eta which is the M20 2.7 low compression engine which was produced for efficency because of the greenies in the '80's. Has he got the rest of the engine it came off?
not 2 sure man i'll need to ask him again he told me it was a 325 block
wat would be the point in puttin that head on a 325? maybe its just BS he was tellin me
Widge
Post
Thu Apr 28, 2005 3:55 pm
I don't see any point using that head for anything, however he may think he has a 2.5 M20 because it came out of a car with 25 on the back. If the rest of the engine is a 2.7 M20 from an eta you could just pop a 2.5 or 2.0 (not really sure) head on it to make a high comp 2.7, just use your inlet, TB injectors etc and get a chip , you'd have a mor powerful puppy than the 2.5. Just an idea. Or if you can get the engine off him sell it on here to fund your new head.
JonnyBravo
Post
Thu Apr 28, 2005 4:00 pm
need to ask him and see but cheers for the info man
- Homo Hair
Post
Thu Apr 28, 2005 4:05 pm
2.7 has a v restricted head and mild cam..
it is nothin like the 325i head.. altho with some work you can fit a 325i cam in there. But dont bother - get a proper 2.5 head
JonnyBravo
Post
Thu Apr 28, 2005 9:14 pm
i can get my hands on the 525e
witch already has the 325i head and all on it but he says its not running right because the engine is still in the 525 with the 525 ECU so it dont rev out the way it should but with the 325 ECU it would run 100%
so would the 525 block fit into my 1989 325i sport then? would i need to change anything else for the engine to fit in my car?
the 525e is a automatic would my getreg gearbox from the 325 work/fit ok?
Widge
Post
Thu Apr 28, 2005 9:22 pm
See this thread
http://www.e30zone.co.uk/modules.php?na ... pic&t=7550
If it has a 2.5 head it should have had domed pistons put in and had the block skimmed. If this is un likley then it may have a 2.0 ltr head on it in which cas it will still be more powerful if it also has 2.5 manifold injectors and afm and 2.5 cam. it should run fine if you pump the fuel pressure up to 3bar with a 3 bar reg and then get a zone 2.7 chip.
By the sounds of things you are lucky to have the makings of a 2.7 for free!
Oh you'll need a different fly wheel as the aut just uses a drive ring plate and torque converter.
