cheers paul.
heater matrix
I recently had a leak in the passenger footwell and found that one of the rubber pipes that are attached to the matrix pipes coming from the bulk head were not tight enough. I tightened the jubilee clip and the leak has stopped but i still aint got no heat coming from the vents!
HTH.
HTH.
i have just fixed the valve and it looked like water was coming from the housing below but then then seemed to stop so going to have another look todayGiggz wrote:I recently had a leak in the passenger footwell and found that one of the rubber pipes that are attached to the matrix pipes coming from the bulk head were not tight enough. I tightened the jubilee clip and the leak has stopped but i still aint got no heat coming from the vents!![]()
HTH.
cheers paul.
