249k miles M50 Pics
BreadBin
Post Tue May 15, 2007 7:00 pm
Changed the rocker cover gasket on the 525i today, thought some of you M50 types might be interested in pics of the cam wear. I thought it looked pretty good considering its on 249000 8)
Humph
Post Tue May 15, 2007 7:43 pm
Dont you just love those hydraulic lifters :cool:
kam-325i
Post Tue May 15, 2007 8:33 pm
Cam lobes are a bit pointy.........
hubble
Post Tue May 15, 2007 8:46 pm
Looking good. Sooooo looking forward to getting there myself :D
JohnnyRob
Post Tue May 15, 2007 9:09 pm
Those engines are bomb proof...
Post Tue May 15, 2007 9:44 pm
Here are some 70,000 mile cams for comparison
Very pointy compared to a worn out M20 cam :)
kam-325i
Post Tue May 15, 2007 10:05 pm
why are they so pointy ?
Even my new'ish M20 cam was not like that....
Post Tue May 15, 2007 10:10 pm
You should see my Schrick cams winkeye
Enough point to poke your eye out
Andyboy
Alpina Colada
Post Tue May 15, 2007 11:03 pm
They're hand made by The Pointer Sisters.
SPADGE
Post Tue May 15, 2007 11:04 pm
So just how much oil were the spark plugs bathing in then :D
Post Tue May 15, 2007 11:32 pm
hows the plastic water pump propeller wrongness on those badboys then?!
BreadBin
Post Wed May 16, 2007 7:42 am
SPADGE wrote:So just how much oil were the spark plugs bathing in then :D
LOL a fair bit! I took the plugs out to drain it into the cylinders, you should have seen my neighbours looking when I started it up :twisted:
Humph
BreadBin
Post Wed May 16, 2007 8:20 am
Simon13 wrote:hows the plastic water pump propeller wrongness on those badboys then?!
I can't comment on that but the f**king oil pump just died on me :-x :x :x :evil: :(
I give up :cry:
edit - ever get the feeling you're not meant to have something? I swear BMWs and me are cursed :(
Humph
BreadBin
Post Wed May 16, 2007 7:59 pm
Can anyone tell me if the sump can be removed with the engine still in the car? I'm thinking my only option is to fix this myself... 8O :? winkeye :roll:
Humph
Jon_Bmw
Dangerous when thinking
Post Wed May 16, 2007 8:32 pm
Take it back the the trader you brought it off!! :wink:
More seriously i'm not sure if the sump will come off in situ. I know on the m20 its a pain in the arse with the engine needing to go up a fair bit to release the sump. Horrible job to be honest.
Post Wed May 16, 2007 9:20 pm
Even if the engine needs raising there is plenty of room to lift it 8)
BreadBin
Post Wed May 16, 2007 9:36 pm
Jon_Bmw wrote:Take it back the the trader you brought it off!! :wink:
I didn't buy it. I don't blame Spadge in the slightest it's just one of those things. It's ironic (to me) that the day after I sort out the tax and the rocker cover gasket it goes wrong but I am getting used to BMWs doing this to me. I may as well fix it as it doesn't look like that bad a job, bloody knew there was a reason I downloaded the Bentley 5-series pdf....
Do I need a new sump gasket? :?
Humph
SPADGE
Post Wed May 16, 2007 9:47 pm
Hi mate rotten luck yet again :(
Obviously i had no idea the oil pump was on its last legs or i certainly wouldn't have driven it all the way to you. With a quarter of a million miles on the clock its had a good innings and of course things don't last for ever.
Are you sure you didn't drop anything into an oil way whilst doing the cam cover gasket as its a bit coincidental it should go just after you did it?
Best of luck with it mate
Spadge...
BreadBin
Post Wed May 16, 2007 9:57 pm
Yep I am having fun this year, it can only get better!
It's not done yet mate - I am going to try and fix it, I barely drove it once the warnings came on and was about 2 mins from home on my way to work.
I am as certain as I can be mate, I was bloody careful :) - I went for a good 60 mile round trip to a mates after doing it and it was fine. I have been deliberately not caning it too, I reckon cars are like women - treat 'em mean, keep 'em keen winkeye
Humph
SPADGE
Post Wed May 16, 2007 9:59 pm
Appart from the oil light coming on what other signs do you have that the oil pump is fecked mate?
BreadBin
Post Wed May 16, 2007 10:12 pm
It's telling me low pressure on the display and the lifters are clattering over about 3.5k ( I only tried this a couple of times ) I know it has the right amount of oil in.
Not sure what else it could be to go that suddenly, I think maybe some crud has moved about where I had the cover off, might be worth trying a flush?
Or some thicker oil, in fact maybe it's because I put some new oil in it :mad:
Humph
