2.8 crank spacer
ed325i
Post Fri May 11, 2007 5:20 pm
right I need to get a crank spacer made up for my m52 2.8 crank.
Now I have come up with the idea of cutting the end from a 325 crank and then getting it machined to fit the end of the m25 crank.
Do people think it will work ?
Turbo-Brown
Boost Junkie
Post Fri May 11, 2007 5:21 pm
Yeah don't see why not, as long as the machinist takes a bit of time to make sure it's running concentric :)
Post Fri May 11, 2007 10:43 pm
Gotta be the best way to go
Ant
Retired Team Member
Retired Team Member
Post Fri May 11, 2007 11:05 pm
M52 outer pulley machined was what I believe Andy used on the TBMW build. afterall, it will fit perfectly and only functions as a sealing face for the seal.
Cutting the crank and then machining would work, but cost far more I'd imagine.
ed325i
Post Sat May 12, 2007 9:29 am
Was it the pulley or this bit ?
Demlotcrew
Post Sat May 12, 2007 9:40 am
I think i have a pic of both cranks side by side.
Andrew
ed325i
Post Sat May 12, 2007 2:01 pm
It must be made from number 6. The pulleys dont look that wide.
e21Jason
Post Sat May 12, 2007 8:36 pm
Hi
Here is a pic of the cransk and the spacer detials
You can buy them from Jeff ireland or Metric Mechanic
Jason
ed325i
Post Sat May 12, 2007 8:41 pm
thanks jason :thumb:
JazzMan
Post Sat May 12, 2007 11:22 pm
ed325i wrote:Was it the pulley or this bit ?
Yup, that the bit I'm going to use on that crank. Luck my dad got a lathe :D
ed325i
Post Sun May 13, 2007 6:54 pm
I just asked andy and it is that part.
ed325i
Post Tue May 15, 2007 7:44 pm
I dropped the pulley bit off at the machine shop today, will be ready friday costing me £15.
ed325i
Post Tue May 22, 2007 5:25 pm
picked it up today 8)
Turbo-Brown
Boost Junkie
Post Tue May 22, 2007 9:00 pm
Ooh, how much did the knee cost? :)
JazzMan
Post Tue May 22, 2007 9:32 pm
Nice :D I'm putting that pic with the rest I've gathered on the conversion :D
