You will want the diff from a Sport though - LSDs are always worth the time and effort to fit
upgrading my 320i - recommendations please!
jmc330i
If you buy a 325i/325iSE, IMO I wouldnt bother going to the trouble of finding and fitting a Sport gearbox, unless the original box is knackered. Its only the first couple ratios that are different, so theres no real point in swapping gearboxes for the hell of it.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
spp320i
James, thanks for your input also, you guys have such a depth and breadth of knowledge, I'd be screwed without the e30zone!
If the gearbox change isn't going to be worth it, then I'll not change it! Definitely want the diff though
Would you recommend doing what you've done to yours? I see you have a rare 330i badge there....!!
jmc330i
If you buy a 325i with a good box, then I dont think it would be worth the hassle. If youre doing other work in the future (like a clutch change for example) and you find a Sport box cheap enough, you could swap the box then or as I said if the box is shagged, but its not something I would do just to have a Sport box.spp320i wrote:If the gearbox change isn't going to be worth it, then I'll not change it!
I will let you know when I get to drive it properlyWould you recommend doing what you've done to yours? I see you have a rare 330i badge there....!!
James
'91 325i Sport
'91 325i Sport
spp320i
Agreed! Now I just need to flog mine, I'll see if there's any interest.If you buy a 325i with a good box, then I dont think it would be worth the hassle.
Oops - forget i asked!I will let you know when I get to drive it properly
jmc330i
spp320i wrote:Oops - forget i asked!I will let you know when I get to drive it properly![]()
Ive had hassle after hassle getting the conversion done, but it will be worth it when its finished - Ive fitted the E36 M3 3.0ltr engine
James
'91 325i Sport
'91 325i Sport
spp320i
James, I didn't want to know that - it'll be worth the hassle in the end, and I'll be green with envy!Ive had hassle after hassle getting the conversion done, but it will be worth it when its finished - Ive fitted the E36 M3 3.0ltr engine
