Bleed nipples
TheDutch
Wed Apr 25, 2007 9:30 am
Does anybody know the size of the bleed nipples on 325i/318is front brake calipers? One of mine has at some point become rounded off and needs replacing. Is it now just a case of mole grips and WD40, or are there any better techniques for removing it?
Cheers,
Dutchship
ed325i
Wed Apr 25, 2007 12:13 pm
I would get the mole grips on there, this is what I end up doing when I cant find the 7mm spaner.
smithy318i
Wed Apr 25, 2007 3:03 pm
Heat. Lots of it.
Blowtorch and molegrips.
IIRC there are only two sizes, and ours are the smaller of the two.
FlappySocks
Wed Apr 25, 2007 3:10 pm
Steelers are a bit pricey on bleed nipples as I recall. Something like £6 each. Just measured the thread diameter of my spare one, and it's 6.88mm
Stuart.
smithy318i
Wed Apr 25, 2007 3:12 pm
Any old autoparts shop will sell them. mine were 50p each.
wildeian
Wed Apr 25, 2007 3:23 pm
Yeah, just changed mine, 7mm spanner.
Mine were rounded too, so I took the caliper off, held the rounded nipple in a vice, and twisted the caliper off of it.
You're gonna need to bleed it anyway, at least this way you get full access to the area :D
New nipples were about £4-£5 from dealers iirc.
TheDutch
Wed Apr 25, 2007 3:25 pm
True, but at my local parts places I was offered two sizes, one with an M8 thread and one with something else. I guess I'll just try and get the one with the 6.88mm thread - thanks for the ridiculous precision!
shknapps
Wed Apr 25, 2007 3:27 pm
carefull with the heat not to hot or you will sofen the nipple .
just done mine.
one snapped .
A trip down the scrappy!!!!
TheDutch
Wed Apr 25, 2007 3:28 pm
wildeian wrote:New nipples were about £4-£5 from dealers iirc.
£4-£5 each!? What are they made of? Human nipples aren't even worth that.
