Is there a breather on the Sport gearbox?
The reason I ask is that I've replaced the output shaft oil seal, but it's still pushing some oil past it. Could it be because the breather is blocked, if there is one...?
Picking the Sport up tonight at last... that's the only outstanding problem with it mechanically now.
Giles.
Sport gearbox breather?
Geeman
CaesarBob
Never heard of a breather on the gearbox before. It's not overfilled with oil is it?
'97 E36 B3 3.2 Touring - Alpina-Blau
'15 F32 420d M Sport Coupe - BMW - melbourne-metallic (Sold)
'11 E92 320d M Sport Coupe - BMW-saphirschwarz-metallic (Sold)
'99 E36 328iA SE "Shooting Brake" - BMW-titansilber-metallic (Sold)
'89 E30 325i
'89 E30 325i
Geeman
Dunno... will ask when I go pick it up in about 10 minutes.... Yay!
Ant
- Retired Team Member
thers a lilttle poppet valve on the top of the gearbox to allow it to breath, problem is its so small and gets gunked up with all sorts of ming over time.
Giles TBH mate most gearbox leak a little out the output shaft seal, the wiper type seal employed will never offer 100% sealing, should mist from that area but certainly if shes chucking loads out thers a problem there M8
HTH
HTH
Geeman
Just picked it up. She runs beautifully now.
Asked about the leak, he said that the flange itself is worn, and it's probably not sealing correctly against that, although I've just replaced the seal itself.
So the next move is to replace the flange... Not now though, just want to drive it for a while... probably do it when it goes back for it's braided brake hoses.
Cheers for the advice though Ant.
Geeman
Ant...
This poppet valve... can you access it with the gearbox in situe, or is it a case of dropping the gearbox off...?
Just had it at the tyre place to have balancing and tracking sorted out, and then the leaky exhaust looked at. While it was up in the air and the engine idling, there were visible drips of fluid leaking from the output seal.
When I picked the car up last night, he said it was still leaking, and thought it was becasue the output flange was actually worn, therefore the oil seal wasn't seating tight enough. He said if I get a new flange, he could fit it with a new seal in about an hour, no problems.
Is it worth seeking out the breather (if accessible) and clearing this out too...?
Thanks for your input...
Giles.
Giles.
