started m50 swap(pics too)
brian325i
Post Sun Apr 08, 2007 2:27 pm
im in ireland so motorways are non existant and if you are one our one motorway its probably stuck in traffic so i dont mind that..
I will what you done to save wrecking my engine bay and no doubt denting it all over the place....plus im doing it in my driveway si anything to make it easier will help..and my driveway has a bit of a slant in it ..(not good)
here is a few of the parts..All with bmw approved parts stickers ha ha
her is the damage i done when taking engine out
do the mounts look right?
exhaust is off
brian325i
Post Sun Apr 08, 2007 2:30 pm
the exhaust, powersteering pump and two mounts..thats all i can do for today..my poor girlfriend is being neglected over the car so i ave to go for a spin and stuff..think i might drop it in tomorrow night to start messin with my manifolds
brian325i
Post Mon Apr 09, 2007 8:33 pm
m50 is in..not sitting on mounts yet but in..
i think one of my mounts might be inside out ..engine is very far over to driver side when close to mounts..
plenty of space for heater pipes..
Post Mon Apr 09, 2007 8:39 pm
Plenty of space for heater pipes = less space for steering shaft and exhaust pipes. There are various ways the mounts can fit in the subframe.
brian325i
Post Mon Apr 09, 2007 8:44 pm
say the passenger side mount..should the threaded bar be on the outside or inside when looking up from under subframe??
Post Mon Apr 09, 2007 9:26 pm
Both of mine were fitted to the outer holes, as are others ive seen
Post Mon Apr 09, 2007 11:54 pm
My notes (written a year or two ago) say: "LH mount is fitted reversed. i.e. stud in slotted hole and locating peg in round hole.
RH mount is fitted stud in round hole and new 10mm hole for locating peg drilled 17mm towards centre of car."
That was for standard M20 rubber mounts.
brian325i
Post Tue Apr 10, 2007 12:02 am
im using e28 m5 mounts..and by sonds of it i reversed the passenger side mount beknown to me..i only noticed when puttin on nut coz it was harder to get at
brian325i
Post Tue Apr 10, 2007 11:44 pm
will an e35 525 auto wiring loom do if i just blank the ecu for the autobox etc...???only thing they had so i took it
Post Wed Apr 11, 2007 12:31 am
You dont need to do anything to the loom except wire in a C101 plug 8)
brian325i
Post Wed Apr 11, 2007 12:35 am
so an it makes absolutely no difference that it has a spare ecu slot???
1993 automatic e34 525 bosch is what it is/came from
anyone know how many sensors/connections should be on the e34 loom..no doubt there is one or two extra for the auto workings..plus i found an e36 325 in scrapyard but car is on floor(no loom init) so the owner said he will have it on its side for me next day..e36 325 prop and linkages=sourced :D
Post Wed Apr 11, 2007 12:58 am
All the E34 looms I have seen have seperate auto box looms that simply plug in to the engine loom via a connector in the ECU/relay box on the drivers side of the engine bay.
Are you sure its from a 525i and not a 325i
brian325i
Post Wed Apr 11, 2007 1:07 am
@dan..i took it out of an e35 525 unless someone put it in to take the piss out of me :mad:
it had 2 "ecu" connectors on drivers side..one was for ecu other was for auto
so i presume i just carry on as if the auto connector isnt there..??????
i gonna try it anyway..that way ye will know for the future..i not lookin forward to matching the sensors up :? :(
brian325i
Post Wed Apr 11, 2007 1:47 am
cover was recked so i said id clean it up..primed and painted silver...gonna finish colours tomorrow
Kedge
Post Wed Apr 11, 2007 2:53 pm
Good looking project, really want to do mine now. How much longer do you think it's going to take you?
I'll be using the 318iS box and diff to make life easier.
Instagram - Kedge85
finny_325i
Post Wed Apr 11, 2007 8:37 pm
@kedge..if i didnt have exams to worry about then not too long..week ot 2 but im studying til 5 and only get an hour a night at the car so its slow progress until weekends..
tonight i got the engine sitting in its mounts..tomorrow im gonna test fit my m52 e/manifolds after i chop and tack em
Left to do:E36 325 prop,gearlinkages
gearbox mount,
cooling
wiring
and all small ancillaries
lot still to do but im happy
m-dtech
Unapproved Trader caution
Post Wed Apr 11, 2007 8:40 pm
brian325i wrote:@dan..i took it out of an e35 525 unless someone put it in to take the **** out of me :mad:
If you trace the autobox loom it should come away from the main loom.
finny_325i
Post Wed Apr 11, 2007 8:42 pm
will do right now..brian here on buddies computer :D
brian325i
Post Wed Apr 11, 2007 11:12 pm
i had a look at it..there are 2 seperate "looms" for about 6inches then all the wires go into the one loom..would i be best off to wire it up and leave the auto loom alone or would i be better off to take it out....anyone have the pin and purpose for an e34 525 1993 m50 wiring loom??
thanks..
i iwll have to get an e30zone sticker for my car seemin as alot of info from here helped it get to where it is..im happy but still loads to do :D
Post Wed Apr 11, 2007 11:39 pm
Ive seperated a 328i auto loom from the engine loom, comes apart easily, only one wire left over that goes to the engine ECU and im yet to work out what it is for.
brian325i
Post Wed Apr 11, 2007 11:55 pm
did your engine work? :D
Post Thu Apr 12, 2007 12:03 am
Ive not fitted it to an engine, I just wanted to seperate it all to see whats what.
I have heard that with the auto loom on a manual, (autobox ecu removed) the engine management light comes on. I was going to look into it to see what sort of signal the one left over wire gives to the engine ECU but never got round to it. I cant see it being hard to duplicate though, may even be as simple as an earth.
m-dtech
Post Thu Apr 12, 2007 12:06 am
also, i take it as your using the e34 loom your gonna move the battery to the boot and put the ecu in the battery bay ?
brian325i
Post Thu Apr 12, 2007 12:07 am
im gonna try take it apart tomorrow..ill let you know how i get on..did you follow each wire and take it out of the plug?
brian325i
Post Thu Apr 12, 2007 12:09 am
@mdtech ..ya thats the plan
Post Thu Apr 12, 2007 12:25 am
brian325i wrote:im gonna try take it apart tomorrow..ill let you know how i get on..did you follow each wire and take it out of the plug?
No, the 2 looms seperate from each other, I only cut the wires to draw them through the insulation.
Heres a pic I took of what I removed
brian325i
Post Thu Apr 12, 2007 11:21 am
im in college now "studying " but i will try that when i go home...i thought they were intertwinned..between the plugs like..
looks ok..thanks for the pic :wink:
brian325i
Post Thu Apr 12, 2007 5:27 pm
itll be ok like this till i get money to buy new standard one..didnt like it with all scratches and stuff....
Post Thu Apr 12, 2007 11:05 pm
The red and blue look good but I would black the cam cover again 8)
eko
Old timer
Post Thu Apr 12, 2007 11:15 pm
Prefer all Black!
No offence Brian winkeye
brian325i
Post Thu Apr 12, 2007 11:26 pm
i gonna put a darker blue /purle in the middle..see wat it looks like then if i still unsure itll be goin back to black..can ya buy a c101 new??
eko
Old timer
Post Thu Apr 12, 2007 11:27 pm
Why do you need a new C101?
brian325i
Post Thu Apr 12, 2007 11:30 pm
the engine plug??thats what its called? i sold my m42 with loom etc
eko
Old timer
Post Thu Apr 12, 2007 11:32 pm
Ah ok!
Well not sure if they are available,might have to source from a breaker?
brian325i
Post Thu Apr 12, 2007 11:36 pm
ya but if i get one theyll charge me for a whole loom.I suppose if it has to be done it has to be done.gonna try have engine running this weekend..which will just leave prop and gearlinkages
