turbo + throttle boddies
midnight
appletree
i think booty man might have on his twin turbo thing, seen it in this months practical performance car. it was on the rollers in walkers work shop
Turbo-Brown
- Boost Junkie
I've got TBs on my M20 TT too
We're multiplying!
What is it you wanna know Midnight?
Ant
- Retired Team Member
Alex has Tb's on his twin turbo beastie. Hard to say where the improvements were though as it was running on a very basic map last I went in it.
Toby Unna's M30T has improved throttle response with the M5 TB's but the overall performance is similar to previous single TB setup.
Expensive mod, lets see what the M30T puts out on the rollers in its new guise
Email FTW
midnight
maxfield
Bike tbs.
Ant
bike TB's are not designed to run pressurised, and a plenum would be a lot of fabrication work, could be done though.
Alex will make a duplicate set of TB's to suit the boosted M20 app, for a price, custom designed, custom made, one offs( but there'd be 2 sets :lol
drop him a PM Kev ?
TB's will alwasy show a gain over a single TB/pleumn style intake, n/a or FI, no 2 wasy abaout it.
The cost worries me though, I'm on a budget
Email FTW
Turbo-Brown
- Boost Junkie
Alex will make a duplicate set of TB's to suit the boosted M20 app, for a price, custom designed, custom made, one offs( but there'd be 2 sets :lol drop him a PM Kev ?
Will be making four sets of M20 throttles when the time comes though to keep the cost per set down, two of which are already accounted for
midnight
Turbo-Brown
- Boost Junkie
Two engine setsmidnight wrote:what do you mean by two sets? do they come in a treble or a double set up? ive only seen throttle bodies in doubles....
and what kind of money would we be talking about??
I make single throttles up to my own design and then fabricate three manifolds up to accept the injectors, throttles and breather pipe. Think I said about £975 for the set but hopefully a little less if the linkage is simpler than the engine I'm working on at the moment
midnight
fowler
- Boost Junkie
what about one large TB and a custom inlet phlenum
EX A-Tech Workshop bitch !!!
gone but not forgotten
Turbo-Brown
- Boost Junkie
Can do, but you need a very progressive throttle linkage (not a problem) and very good resolution on your load sensors, especially if throttle angle's involved in any way.what about one large TB and a custom inlet phlenum
midnight
cplagz
ITB = INDIVIDUAL throttle bodies.... so 1 throttle body per cylinder.
midnight
Turbo-Brown
- Boost Junkie
You have one throttle per cylinder and a linkage which connects them in such a way that when you press the accelerator pedal, the throttles all open by the same amount.
You can put your throttle position sensor pretty much anywhere on the linkage, but reading directly off the the butterfly spindle is probably best.
The positions sensors can be from pretty much anything as long as they're sensors and not switches like the standard M20 has.
The throttles do all need balancing so that the idle's smooth and all cylinders get the same amount of air. I prefer to make mine all independently adjustable as it's easy to adjust them that way, and if one goes out of adjustment for whatever reason, it doesn't take the rest with it.
Problem I have with bike TBs and various aftermarket systems is that the throttles all reference eachother directly and, especially on an inline 6 engine which is quite long, you've got dinky little linkages all pushing against multiple springs and twisting spindly little spindles so there's lots of potential for things to go out of adjustment
midnight
