it all started in halfords when i started her up, shge ran for about 2 minutes and then she just cut out. then i tryed to start her but she didnt want to. i left her for 5 mins and she started again no problems, now she decides to cut out on some stops or even when im driving. can some 1 help?
BIG BAD PROBLEM
- beemer_twins
hey guys i've had this problem with my car for the past 3 days.
- beemer_twins
- beemer_twins
We could guess all day long.
Could be crank sensor or fuel pump too.
Need to know if your getting a spark when it fails to start.
M
Not likely as it would still start then stall.Greeny wrote:At a guess it could be the Idle Control Valve.
Possibly, id check for a dirty / worn contacts in the rotor / cap.maxfield wrote: I'm guessing sometihng to do with spark.
Distributor?
Rotor arm?
M
- Brianmoooore
Sounds very much like the kind of thing a dying crank sensor does.
Try to post in the right forum please!!
tristan325
Had a similar problem once. Turned out to be a dodgy DME relay.
cliffybabe
- Powered by Nelly
i saw ur motor at the cruz on thursday night
- beemer_twins
- Brianmoooore
If it has sparks when faulty, it's not the crank position sensor or the DME relay.
Probably fuel related. (Relay or pump).
Take the rear seat base off, so you can hear the fuel pump (or not).
- beemer_twins
john325tewerin
I'd go with Brian's suggestion on this one.
Sounds like lack of fuel pressure either thru supply or regulator.
Hope you get it sorted.
