My S50 swap.. Progress and questions
Post Thu Apr 05, 2007 11:39 am
buster wrote:ouch :( hope she's ok :)
Yeah she is now.. At the time tho had to basically carry her down stairs n out to the car n she was very shocked, 6 stitches in the end
Post Thu Apr 05, 2007 11:42 am
ian332isport wrote:
Jhonno wrote:With the positive power cable that would have been for the e36 fuse box, there is what looks like an earth wire.. Does that need cutting and tidying also?
You should not be cutting any earth wires at all. Assuming these are a few different sizes of brown and/or brown /orange wires in a black sleeve, then they should go to the earthing point on the drivers side strut tower (or any other suitable earth point).
Ian.
It comes out of the passengers side, small black wire.. I'll earth it then
ian332isport
Post Thu Apr 05, 2007 12:22 pm
Ian.
Make 100% sure it contains brown or brown/orange wires (inside the sleeve). BMW does not generally use black for ground, so be very careful. It's quite common to find a red (live) wire inside a black outer sleeve, and you really don't want to be putting this to ground 8O
Ian.
Post Thu Apr 05, 2007 4:24 pm
ian332isport wrote:
Jhonno wrote:
ian332isport wrote: You should not be cutting any earth wires at all. Assuming these are a few different sizes of brown and/or brown /orange wires in a black sleeve, then they should go to the earthing point on the drivers side strut tower (or any other suitable earth point).
Ian.
Ian.
Well the one on with the diagnostics plug was an earth the small lead with the fuse box earth was a live.. Does it need to be connected or is it surplus like the fuse box one?
ian332isport
Post Thu Apr 05, 2007 4:27 pm
Jhonno wrote:
ian332isport wrote:
Jhonno wrote: It comes out of the passengers side, small black wire.. I'll earth it then
Ian.
Fuse box earth ??
I'm really confused now. I think you best take a couple of pictures. You don't want to be feeding any earth wires into the fuse box.
Ian.
jmc330i
Post Thu Apr 05, 2007 5:01 pm
ian332isport wrote:
Ian.
Jhonno - does it look anything like this?....
On my B30 loom, the 'black' wire (arrowed) is a red live with a black outer sleeve as Ian said - infact, I think I asked Ian about the exact same wire.
James
'91 325i Sport
'93 318i touring 16v
Post Thu Apr 05, 2007 6:17 pm
Yup those are the ones im talking bout :)
Post Thu Apr 05, 2007 6:29 pm
Roll back the rubber sleeve at the end, so that you can see the true colour of the wire.
Any brown or brown/orange must be earthed, and any red, at the battery end, goes to battery pos., except for a possible red that just 'passes through' the loom on it's way to the fusebox, and now may be duplicating an existing E30 wire.
orr
Post Thu Apr 05, 2007 8:40 pm
The top black wire is red inside and it is the live wire for the starter motor relay i have just done mine it will not crank without it. found this out from ian332sport.
Post Fri Apr 06, 2007 7:50 pm
Right guys.. Just need some clarification of what lives are needed n which arent.. Im gonna run the standard e30 fusebox live so does that mean i can tape up the one in the s50 loom? you have the 2 lives which come out the drivers side of the wiring box which will be connected, and it sounds like i have to run the small black live round to the drivers side from the passengers side.. The red wire with the starter relay live, that is the s50 fusebox live yeah? In fact thinkin about it, it will be tidier to use the s50 live into the fusebox wont it? i assume it gets power from the loom?
Post Fri Apr 06, 2007 8:25 pm
When I modded an S50 loom I removed all the surplus live cable, if you cut off all the conduit/sleeving and insulation its a lot easier to see whats what
Post Fri Apr 06, 2007 8:35 pm
that is what im trying to find out!! Which ones i need n which i dont..
Post Fri Apr 06, 2007 8:45 pm
Well you can remove the lead for the E36 fuse box for a start
Post Sat Apr 07, 2007 7:08 pm
Fucking immobilisers!!! :x :x :x :x :x
Post Sat Jun 30, 2007 8:42 pm
Bit of an update
Car is being trailered to a fitter to have the alarm looked at Tues afternoon.. Soon find out if the engine actually works or not!
Still to do..
- Sort throttle cable
- Some form of air filter
- Manifolds/exhaust
- Tidy wiring
- Brake servo/master cylinder
- Usual odds and sods, finish mounting bits here and there etc
Then its ready for its MOT!! (I think..) :cool:
jaistanley
Post Sat Jul 07, 2007 11:41 am
Fantastic stuff Johno... I was just looking at your post on E3024V and I cant beleive how similar our cars are, or at least how similar yours is to how I want mine to end up!
If I ever get the b***ard on the road we'll have to meet up for some Zone photos!
Jai
Post Sat Jul 07, 2007 4:29 pm
Still wont stat.. :evil: :evil: :evil: :evil:
Might be down to the fact it was an auto and the inhibito.. Attempting to get ound it
Laptop is fucked btw, so bad spelling/english
Post Sat Jul 07, 2007 8:03 pm
Now canks on the key thanks to the legend that is Ian.. BUT now doesnt appea to be spaking..
Post Sat Jul 07, 2007 11:20 pm
You appear to have a problem with your R's Johnno :moon: :teehee:
Post Sun Jul 08, 2007 7:50 am
:lol: No kidding.. I feel like im eading some 'special' kids witing when i ead back though it :o: :mad:
Post Sun Jul 08, 2007 9:17 am
Its like a forum impersonation of Johnathan Woss :D
beardymat
Post Sun Jul 08, 2007 9:34 am
comedy keyboard is cool :cool:
Post Sun Jul 08, 2007 2:34 pm
Maybe i should use w's to weplace fo a full on Jonathon Woss impwession?!
Post Sun Jul 08, 2007 5:36 pm
Pic..
This is a tiny past tdc on the inlet/combustion stoke..
Flat on the font pulley is pointing just past diectly up..
Post Sun Jul 08, 2007 5:37 pm
Obviously this is Cyl 1..
old_skool
Post Sun Jul 08, 2007 5:41 pm
Jhonno,
What is that pic twying to wepwesent?
Post Sun Jul 08, 2007 5:47 pm
Pulley flat is sitting pointing to the altenato backet, so id say about 1.30/2 o'clock position..
Post Sun Jul 08, 2007 5:50 pm
Feck off :P :lol:
It wont fiwe atm, twying to check the timing.. Pwetty much the only thing left. Its fiwing balls of flame out the exhaust powts but not twying to catch..
Been on the phone to Ian fow a considewable time nawowing it down to timing ow compwession.. It has at least some compwession..
ian332isport
Dan,
Sorry to say it, but that looks very wrong.
This is a picture of an M50/52 taken from the E36 Bentley manaul, but it should be basically the same on the S50.
Ian.
Post Sun Jul 08, 2007 5:52 pm
Bollocks.. :(
How do i go about setting the timing cowectly then? Ow is it a deala job?! :(
ian332isport
Post Sun Jul 08, 2007 6:05 pm
Jhonno wrote:Bollocks.. :(
To be honest, I'm not sure how much of a job it is. I suspect it's relatively easy if you have done it before, but a turd of a job if you haven't. I've never had to mess with cam timing, or Vanos, so don't really know what's involved. I do know the procedure is in the TIS, but I still don't have my copy to look at.
Ian.
ian332isport
Post Sun Jul 08, 2007 6:11 pm
Dameon,
While you have the top off your engine, is there any chance you could wind it to TDC on No1 cylinder and take a similar picture to Dan's above ?
This would help to confirm 100% that Dan has 'issues'.
Cheers,
Ian.
old_skool
Post Sun Jul 08, 2007 6:15 pm
No problem, I can whip the top off tomorrow if that helps guys?
ian332isport
Post Sun Jul 08, 2007 6:17 pm
old_skool_2002 wrote:No problem, I can whip the top off tomorrow if that helps guys?
That would be superb :cool:
Post Sun Jul 08, 2007 6:20 pm
8)
