Evenin all,
A little step closer to hearing some noise,
With the engine removed again to tidy up some loose ends
before it can be started we had to first sort out a working dipstick.
The old dipstick could no longer be used as it was sticking down
into a place where we had shortened the sump, so as luck would
have it, beside the hole in the block where the dipstick tube threaded
in was another hole for an oil temp sender.
so out came sender, in went shortened dipstick tube, and with the
sender cut down and welded up as a bung, it went back in to fill the
old empty distick hole.
the reason we had to cut down the original dipstick tube in height
was that the new hole for it had it right under one of the manifold
branches. So chop, chop, bend, bend and screw, screw has it left like
this...................
next up was the sump. As it was only loosely bolted up first time to
check it would clear the crossmember it was now time to bolt it up oil
tight. First up was a lick of paint...............
then get a gasket cut up and bonded down to the block...............
then fit el sumpo..............
actually just before the engine was lifted out this time we got the
gearbox mount made up. We used most of the bm mount and just made
a cradle to bolt to the box which then sat on the original mount.
with the engine removed it also gave us a chance to cut the gearbox
tunnel. The new engine and box has the gearlever 40mm more forward
of the original hole, so, half a new hole had to be cut and half the old
refilled. Which came out looking like this from underneath
and this from above.................
a ford gearlever booth then keeps the elements out in the cabin
also sorted was the rest of the exhaust system. With the 2
manifolds made we now needed a collector to run from them
into the rest of the system. There now should follow pictures of
beautifully formed pipes made on a no expence spared state of
the art computerised pipe bender. But the lotto numbers haven't
come up yet so what you get is a selection of bends robbed from
the local fast fit's waste skip, which look like this................
and a bridge piece welded in to secure this section to the gearbox
next up was the fuel pipes. The originals ran to the bm fuel tank
under the rear seat and as this was now gone and replaced with a small
fuel tank in the boot we decided to run some new pipes.
Starting in the engine bay..............
down the floor pan.................
squiggle, squiggle.................
and as we didn't want to try and follow the complex bends of
the hole where the old tank used to be we weld in some flat to take
the pipe on a straighter route...............
over the axle and into the spare wheel well....................
and plumbed into the rest of the fuel cell which is nearly complete
the trip to the scrap had also turned up a new header tank with
the right size outlets in the right places................
which has allowed us to start finishing off the water plumbing...........
we also managed to get the accelerator cable sorted. We used the
original Alfa cable with the pedal end chopped off and fitted a cross
drilled headed bolt to the bm's accelerator pedal to retain the inner cable.
The bolt isn't run up tight so as when the pedal/arm moves the cable pull
always remains straight.
Engine bays starting to look a little fuller now, hopefully smoke (of the
right sort) ain't that far away..............
Good night,
God bless,
much love.
