Jetronic/Motronic
oneblueleg
Jetronic - Motronic - how do you know which it is?
Davenotouring
There is probably another way...but....
If you take off the panel underneath the steering wheel, the ecu is just under there and will have a label/stamped into it Motronic/Jetronic
BMW 328i Cab - Daily Slag
jay528ise1985
You can also take a look at the distributors - If you've got an old fashioned one you'll have Jetronic.
1989 BMW 320i 2.7 2 door saloon
oneblueleg
What's an 'old fashioned' one look like?jay528ise1985 wrote:You can also take a look at the distributors - If you've got an old fashioned one you'll have Jetronic.
Davenotouring
The new one is on the end of the cam, (motronic) the old one is down on the block.
Easier answer there.
MONSPORT42
What car is it? M20? Series 1, Series 2, Year? Might be able to tell what it's supposed to have.
YOUR LEFT FOOT'S FOR BRAKING
jay528ise1985
Heh heh!
Davenotouring
jay528ise1985 wrote:The new one is on the end of the cam, (motronic) the old one is down on the block.
Heh heh!
Forgot about that I did!
jonb
jetronic has a dizzy. motronic doesnt, it just runs the rotor off the end of the cam.
jetronic has a dizzy on the crank case, on the left hand side of the engine.
