I have got a manual sun roof at the moment but wont be able to use it because the roll cage will get in the way of the handle, So how can I convert it to electric ??
What parts will I need ?
electric sun roof conversion ?
dazleeds
- old skool raver
as far as i know all ya need is the motor with the mounting bracket
and possibly the black trim with switch hole instead of the handle cutout
cant remember if the wiring is there already??
www.oldskoolfantasy.co.uk
ed325i
I have got the black trim.
It wont have the wiring Its got no elec windows / central locks. But it shouldnt be to hard to wire it up
if I get the whole loom.
oze30
Theres a white plug with 1 wire I think. You'll possibly need the tubes aswell, unless you want to drill out rivets and replace with bolts, THEn try and cut the backing plate to fit the elec motor.
It can be done, just a ball ache. Your better off fitting the whole elec roof mechanism.
Chris-W
oze30
However, if you want to go the difficult way, I do have a spare sunroof motor here
Sunroof motor on its own for some strange reason doesn't fit. Can be bodged together, but the spacing of the existing threaded holes on the mounting plate don't quite match the motor!.oze30 wrote:However, if you want to go the difficult way, I do have a spare sunroof motor here
Complete plate and motor, with tubes is by far the easiest way.
ed325i
Ok thanks for the info.
So that means the motor I just got is no good
oze30
not entirely. You can make it fit.. Have done it before.
The backing plate is different man to elec motors. they're flatter, without the cutout for the rear of the motor.
ed325i
Thanks I have got to put the black roof lining in so I will have a look when it all striped out.
I've done one just fitting the motor and the front part of the mounting plate as well. I posted about the problems that arose and their solutions.
Do a forum search and go back to the older posts.
