electric sun roof conversion ?
ed325i
Post Sun Mar 04, 2007 10:16 am
I have got a manual sun roof at the moment but wont be able to use it because the roll cage will get in the way of the handle, So how can I convert it to electric ??
What parts will I need ?
dazleeds
old skool raver
old skool raver
Post Sun Mar 04, 2007 10:19 am
as far as i know all ya need is the motor with the mounting bracket
and possibly the black trim with switch hole instead of the handle cutout
cant remember if the wiring is there already??
www.oldskoolfantasy.co.uk
ed325i
Post Sun Mar 04, 2007 11:07 am
I have got the black trim.
It wont have the wiring Its got no elec windows / central locks. But it shouldnt be to hard to wire it up :roll: if I get the whole loom.
oze30
Post Sun Mar 04, 2007 12:16 pm
Theres a white plug with 1 wire I think. You'll possibly need the tubes aswell, unless you want to drill out rivets and replace with bolts, THEn try and cut the backing plate to fit the elec motor.
It can be done, just a ball ache. Your better off fitting the whole elec roof mechanism.
Chris-W
Post Sun Mar 04, 2007 12:19 pm
As above, best to take the motor with the mounting plate and cable tubes intact.
oze30
Post Sun Mar 04, 2007 1:05 pm
However, if you want to go the difficult way, I do have a spare sunroof motor here
Post Sun Mar 04, 2007 2:39 pm
oze30 wrote:However, if you want to go the difficult way, I do have a spare sunroof motor here
Sunroof motor on its own for some strange reason doesn't fit. Can be bodged together, but the spacing of the existing threaded holes on the mounting plate don't quite match the motor!.
Complete plate and motor, with tubes is by far the easiest way.
ed325i
Post Sun Mar 04, 2007 4:22 pm
Ok thanks for the info.
So that means the motor I just got is no good :cry:
oze30
Post Sun Mar 04, 2007 6:04 pm
not entirely. You can make it fit.. Have done it before.
The backing plate is different man to elec motors. they're flatter, without the cutout for the rear of the motor.
ed325i
Post Sun Mar 04, 2007 6:15 pm
Thanks I have got to put the black roof lining in so I will have a look when it all striped out.
Post Sun Mar 04, 2007 8:43 pm
I've done one just fitting the motor and the front part of the mounting plate as well. I posted about the problems that arose and their solutions.
Do a forum search and go back to the older posts.
