tee
e30_Turbo
- Boost Junkie
Post
Fri Feb 23, 2007 10:13 am
There are a couple of people running that manifold, IIRC oil filter needs rotating or remote mounting to fit it.
Ben, AKA Fowler has one, as does Kevin, AKA Midnight. Ants played with them too so may be able to offer some advice.
Holset HX35 fit these really well too
Jon_Bmw
- Dangerous when thinking
Post
Fri Feb 23, 2007 10:15 am
What are you doing on here, go test fit it
Was it for a RHD car then, or lhd?
Ant
- Retired Team Member
Post
Fri Feb 23, 2007 10:16 am
beg to differ Mark, Fowler has the proper manifold made from 2.6mm stainless, not the ebay copy.
Tee, make sure and wrap that puppy, they go almost transparent in use due to the thinwall design....
Email FTW
cliffybabe
- Powered by Nelly
Post
Fri Feb 23, 2007 10:17 am
Tee that looks fat
e30_Turbo
- Boost Junkie
Post
Fri Feb 23, 2007 10:32 am
Ant wrote:Ben, AKA Fowler has one
Good point, I do remember you mentioning Fowlers used much thicker SS in construction than most. Shouldn't be much longer till you get to show everyone what it looks like with a Proper turbo bolted on to it
tee
Post
Fri Feb 23, 2007 10:40 am
Ill get miniblob to wrap it
he's getting good at it now
tee
Post
Fri Feb 23, 2007 10:42 am
How much did fowler pay for the proper one? I heard it was about a grand. Just interested ti know the price differance
jaistanley
Post
Fri Feb 23, 2007 12:55 pm
Ian (I think) posted a link to a ceramic coating company...
It'd be worthwhile having it ceramic coated inside and out wouldn't it? You could wrap on top of that too..
Jai
sam325is
Post
Fri Feb 23, 2007 12:57 pm
willg here, if your bolting a turbo like a H1C or HX35 it would be a good idea to brace turbo to the point were it sits there without beign bolted to the manifold. Honda tuners have used manifold made by same people and alot of people have had problems with them, the ones who didnt said its becuase you need to brace and posted a picture of their turbo sitting there without a manifold there. you need to brace the turbo, do not brace or attempt to reinfore or brace the manifold becuase it will crack like that aswell. It will probly hold a small cossie turbo without any problems though
sam325is
Post
Fri Feb 23, 2007 1:00 pm
the best manifolds are PPF and jon volk which are about £600 i think
march109
Post
Fri Feb 23, 2007 1:03 pm
sam325is wrote:willg here, if your bolting a turbo like a H1C or HX35 it would be a good idea to brace turbo to the point were it sits there without beign bolted to the manifold. Honda tuners have used manifold made by same people and alot of people have had problems with them, the ones who didnt said its becuase you need to brace and posted a picture of their turbo sitting there without a manifold there. you need to brace the turbo, do not brace or attempt to reinfore or brace the manifold becuase it will crack like that aswell. It will probly hold a small cossie turbo without any problems though
got a link to the pics to see what all this is about?
Turbo-Brown
- Boost Junkie
Post
Fri Feb 23, 2007 1:41 pm
Oooh, shiny!
We'll have to sort out those bottom end bits soon Tee
Incidentally, thicker material isn't necessarily an advantage on turbo manifolds as it extracts heat from the gas quicker than thin material would.
That said, it does need to be thick enough to provide mechnical support for the turbo.
325i Twin Turbo (until 10am 01/12/07
www.air-in.co.uk free M20
exhaust and inlet flange
tee
Post
Fri Feb 23, 2007 3:19 pm
jaistanley wrote:Ian (I think) posted a link to a ceramic coating company...
Jai
Need to know more about this ceramic coating! have heard alot about this
E30_Aza
Post
Fri Feb 23, 2007 4:00 pm
tee, have you seen those turbo kits on ebay that are going for £1200???? that looks like the same manifold thats in the kit.
gcorky
- Boost Junkie
Post
Fri Feb 23, 2007 4:49 pm
looks similar to thge ITG i have?
525 sport
BMW_YARD
Post
Fri Feb 23, 2007 8:24 pm
sam325is wrote:the best manifolds are PPF and jon volk which are about £600 i think
What about this one?
Ant
Post
Fri Feb 23, 2007 8:26 pm
Nothing wrong with a log manifold on a turbo car. equal lenght is not a requirement.
the BBR unit is spot on, perfect fit, superb quality.
Looks like Peters Floor ( Emotechnic)
Email FTW
jaistanley
Post
Fri Feb 23, 2007 10:01 pm
Is the bbr one expensive (I have a spare M20 with 65,000 easy miles on it
Jai
miamistu
Post
Sat Feb 24, 2007 12:24 am
Any idea how many BBR manifolds there are in existence?
Ant
Post
Sat Feb 24, 2007 1:07 am
I've seen 5.
rumour was 13, but who really knows ?
Email FTW
