If it was showing 125 down that bypass, you can knock off 10% for sure, and probably more.
And under-profile tyres will only make things worse.
So why does mine seem spot-on?
As a few of you may know, I'm after a new diff, so I've been doing a little checking to see what might be suitable. The car is a 1989 320i with the original 4.1:1 small-case diff which is currently whining like a spoilt kid.
These are apparently quite rare and fragile, so I popped over to http://www.unixnerd.demon.co.uk/bmw.html and used the gearing calculator there to help me find an alternative (3.91 looks best).
Funny thing. Slotting the appropriate figures in (205/50/15 tyres, 5th gear 0.81:1, final drive 4.1:1, 6500 rpm redline) gives a speed of 134 mph, which is what my speedo has shown on the few occasions I've pulled those revs in top gear.
The engine is lightly modified (325 TB, eBay chip (digi-technik), single-box stainless twin-pipe exhaust), but enough for a genuine 12mph over the 'official' top speed (197 km/h, 122mph)?
I checked the maths myself, just in case John G. Burns can't do multiplication:
Rolling diameter = 15"x25.4mm + 205mm = 586mm
x pi for circumference = 1.84 m/revolution
6500 rpm /60 =108.3 revs/second
divided by 0.81 (fifth gear) = 133.7
divided by 4.1 (final drive) = 32.6 revs/second
multiplied by the tyre circumference (1.84 m) = 60 m/s
Which is : 216 km/h or 134 mph!
So John can do maths (and so can I!)
Does anyone have any idea what's going on here? Have I created a very fast 320i? Is it actually a 323/325 and I didn't know? Is my eyesight failing? Or is my tacho over-reading, too?
Answers on a postcard......
