Something's not right...or is it?
handpaper
Post Thu Feb 22, 2007 12:37 am
As everyone knows, speedometers over-read.
If it was showing 125 down that bypass, you can knock off 10% for sure, and probably more.
And under-profile tyres will only make things worse.
So why does mine seem spot-on?
As a few of you may know, I'm after a new diff, so I've been doing a little checking to see what might be suitable. The car is a 1989 320i with the original 4.1:1 small-case diff which is currently whining like a spoilt kid.
These are apparently quite rare and fragile, so I popped over to http://www.unixnerd.demon.co.uk/bmw.html and used the gearing calculator there to help me find an alternative (3.91 looks best).
Funny thing. Slotting the appropriate figures in (205/50/15 tyres, 5th gear 0.81:1, final drive 4.1:1, 6500 rpm redline) gives a speed of 134 mph, which is what my speedo has shown on the few occasions I've pulled those revs in top gear.8)
The engine is lightly modified (325 TB, eBay chip (digi-technik), single-box stainless twin-pipe exhaust), but enough for a genuine 12mph over the 'official' top speed (197 km/h, 122mph)? :eek:
I checked the maths myself, just in case John G. Burns can't do multiplication:
Rolling diameter = 15"x25.4mm + 205mm = 586mm
x pi for circumference = 1.84 m/revolution
6500 rpm /60 =108.3 revs/second
divided by 0.81 (fifth gear) = 133.7
divided by 4.1 (final drive) = 32.6 revs/second
multiplied by the tyre circumference (1.84 m) = 60 m/s
Which is : 216 km/h or 134 mph!
So John can do maths (and so can I!)
Does anyone have any idea what's going on here? Have I created a very fast 320i? Is it actually a 323/325 and I didn't know? Is my eyesight failing? Or is my tacho over-reading, too?
Answers on a postcard...... :?
chief
Post Thu Feb 22, 2007 1:07 am
impressive mathematics here , pythagorous would be proud.
only problem i can see here is the rolling radius
15" is the alloy diameter, what about 205 / 50 / 15 . 50 being the profile and thus adding upto ,more than 15" ,
not sure i am correct :roll:
Don't you wish there were a knob on the TV to turn up the intelligence? There's one marked 'Brightness', but it doesn't work.
handpaper
Post Thu Feb 22, 2007 2:05 am
Quick edit - 'Rolling radius' should have read 'Rolling diameter'
This is the total diameter of the wheel+tyre and is made up of the wheel diameter (15" or 381mm) plus twice the sidewall height (2x50% of 205mm = 205mm) => 586mm.
chief
Post Thu Feb 22, 2007 10:52 am
hi m8
i think the side wall is not that easily measured.
for example a new tyre as 7mm+ of tread giving 14 mm more on the rolling circumference
when down close to the legal limit there is at least 10mm less than before
:mad: :mad: :mad:
:idea:
now where is that box of nurofen
dazleeds
old skool raver
old skool raver
Post Thu Feb 22, 2007 10:59 am
check it with a satnav device
my tech 1 reads around 4mph quicker on the clocks than its realy doing
have tested this as various speeds
www.oldskoolfantasy.co.uk
d6dph
Post Thu Feb 22, 2007 11:03 am
Yup, Daz is right, Easiest way to check it is nav/gps radar detector.
My 325 reads +5mph across the board.
dazleeds
old skool raver
old skool raver
Post Thu Feb 22, 2007 11:06 am
d6dph wrote:Yup, Daz is right, Easiest way to check it is nav/gps radar detector.
all that maths for nothing :lol: :lol:
chief
Post Thu Feb 22, 2007 11:10 am
impressive though :)
orangecurry
Post Thu Feb 22, 2007 11:54 am
chief wrote:hi m8
:mad: :mad: :mad:
:idea:
Just for info, 10mm less doesn't make that much difference
would be 576mm (instead of 586mm) rolling diameter, so 1.8 m tyre circumference (instead of 1.84), so 58.68 m/s (instead of 59.98 m/s) :D
chief
Post Thu Feb 22, 2007 11:59 am
if 10mm don't make no difference then why bother with the einstein mathematics
orangecurry
Post Thu Feb 22, 2007 12:56 pm
chief wrote:if 10mm don't make no difference then why bother with the einstein mathematics
10mm on the tyre diameter doesn't make THAT MUCH difference, but you still have to do the maths to work out your speed.
chief
Post Thu Feb 22, 2007 1:11 pm
ok m8
reckon the sat nav is way to go
