M30 Engine Mounts
e30Alex
hey, im considering making the mounts myself,due to cost.all i need is blueprints with lengths and angles widths etc.I know this is a long shot, but can anyone help me?Cheers Alex
Im a two car man. Shame my bike gets used more.Damn the MOT!
ed325i
I put the engine in with the metal plates on the block and then made a carboard template and then cut the box section the right size using the templates. I then tack welded it altogether and then removed the mounts from the engine to be fully welded.
The mounts cost me £15.
e30Alex
hey thats cool,am capable i think of that i think, im just wondering how you positoined the engine squarly and how you knew the 'correct position'. Sorry 'bout the daft questions, thanks Alex
Toby_Unna
- Boost Junkie
vertical positioning is dictated by clearance between sump and steering rack (need a good few mm)
left to right position by crank centreline
left to right tilt - i just guessed it, the back face of the inlet manifold should be about vertical
front-rear tilt is fixed, because the box bolts up on the e30 crossmember as usual so once you have the sump-rack clearance set you're there
e30Alex
idont get how u worked crank certreline out?Also without the engine being bolted in,is it possable to connect the box to set the front-rear tilt?Im so sorry for these daft questions!Cheers AlexToby_Unna wrote:
candyman
Bought my mounts from company called spoox components they put the engine in position 2.5 (no bulkhead modifications and u can use standard e30 m3 propshaft )
cost me 117.50 plus p+p
Stuart
Stuart
IF YOU CANT BE CAREFUL BE SIDEWAYS
e30Alex
cheers stuart,just checked out their website.have you completed your conversion?if so did you actually use the m3 prop - i cant find any!i take it they bolt on to an open standard e30 diff,or do they only connect to a lsd/or m3 diff?Also im taking it that you use the m30 and m30 box?Cheers once again Alex
candyman
havent completed yet but thay have completed two now and tell me it all fits
think the prop ends are all the same but someone on here will be able to give u a definate answer on that and i am using e34 m30 with 5 speed manual box
Stuart
Stuart
ed325i
Drop the engine in with gearbox, bolt the rear gearbox mount up, put the prop on so you can see how much slide there is left , put a bit of 10mm ply under the sump of the engine. You can move the engine over abit to give you more clearance between the steering and the exhaust maifold but you will have to fit a smaller servo, a golf gti mk1 works well with no mods. Then make the mounts.
charlE30
ed325i wrote:Drop the engine in with gearbox, bolt the rear gearbox mount up, put the prop on so you can see how much slide there is left , put a bit of 10mm ply under the sump of the engine. You can move the engine over abit to give you more clearance between the steering and the exhaust maifold but you will have to fit a smaller servo, a golf gti mk1 works well with no mods. Then make the mounts.
Charlie
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
ed325i
give it ago and see if it hits, I moved the engine over abit so I had less room.
Andy335Touring
5mm should be OK, have you ground the casting seam off the manifold ?
charlE30
Yes mate, I reckon it'll work but will just have to wait and see..Andy335Touring wrote:5mm should be OK, have you ground the casting seam off the manifold ?
BMW F31 335d xdrive
BMW F31 335d xdrive
Andy335Touring
Have you got much left too do ?charlE30 wrote:Yes mate, I reckon it'll work but will just have to wait and see..Andy335Touring wrote:5mm should be OK, have you ground the casting seam off the manifold ?
charlE30
Wiring's all done now, all coolant pipe work done, diff fitted just got to get three bolts for gearbox end of prop.. it's fabricating the downpipe to exhaust system that's holding me back as I'm teaching myself to weld
then that'll be it.
I've had a lot of other commitments recently so haven't had as much time as I'd have liked to tinker with the project so I've moved over to working nights now so I can have 4 day weekends
then that'll be it.
BMW F31 335d xdrive
BMW F31 335d xdrive
Andy335Touring
charlE30
Andy335Touring wrote:it will be nice to meet up again this summer with your beasty all done
BMW F31 335d xdrive
BMW F31 335d xdrive
Toby_Unna
- Boost Junkie
a plan indeedcharlE30 wrote:Andy335Touring wrote:it will be nice to meet up again this summer with your beasty all done
Sounds like a plan dude
you're probably better at welding than me Charlie, i'm self 'taught' too
charlE30
I reckon when it gets warmer we should organise a midlands (ish) 335 meet
BMW F31 335d xdrive
BMW F31 335d xdrive
e30Alex
Yes, hopfully mine will be done to....if i ever find an engine.....
charlE30
Alex I recently bought an E34 535 throttle cable from a guy on ebay, his user name (on ebay) was custom-conversions and he was breaking a complete 535.. he had an engine available. Unfortunatly I don't have his phone number but you could try contacting him through ebay.
I will keep a look out for a suitable engine for you
Charlie
Charlie
BMW F31 335d xdrive
BMW F31 335d xdrive
charlE30
BMW F31 335d xdrive
BMW F31 335d xdrive
