now i understand turbos to a point, c.r's afr's detonation charge temp etc....
but after considerable research theres somthing i cant completely get my head around.....ignition(at least ignition on n/a-fi conversions)
as far as i understand, to covert the m20 ill need a relevant sized turbo+intercooler, manifold/downpipe, all hoses, oil feed to turbo etc but whats the deal on the sparky side of things?
i want to run stock rebuilt bottom end, soo thats under 10psi boost, what do i use?my guess is a fully reprogrammable ecu is ott,soo fmu + rising fuel pressure reg?which fmu's are adjustable and i assume to use fuel pres reg at same time?not best clued up soo do these run piggy back or stand alone...just f.i ignition info please
this is for b road anctics mainly but does have to be used as a daily drive on occasions soo a mild cam will be going in when checking head, just want a bit of boost please sir
